need advise on my 93 12valve - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by slickricks7.3, this thread has received 2 replies and been viewed 2527 times.
post #1 of 3 (permalink) Old 03-15-2011, 12:22 AM Thread Starter
Just strokin an smokin
Send a message via AIM to slickricks7.3
my first 12 valve 93 extened cab 4x4 3/4 144,xxx auto from arizonia
already did intake an 5in stack,an od mod with the pod works great
what should i look in too . Fuel pump ? i know i put a second one on my 24 an it was great. i Plane on tweaking the pump but should i upgrade the fuel system first or what ? im not gona go crazy with the truck. just want some more pep. an a little coal . i do plan on swapping in a 5 speed. An do i have to worry about the Killer Dowel Pin on this year ?
please any an all info would be greatly appreicated thank you all for your time
Rick
slickricks7.3 is offline
post #2 of 3 (permalink) Old 03-17-2011, 03:56 AM
ADMIN/MAFIA
neeltburn's Avatar
Tab the KDP for sure, do a lift pump. get some gauges in it. Then do your power upgrades and tranny swap.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 3 (permalink) Old 12-06-2013, 05:50 AM
Power upgrades are easy first off gauges , then you can do a fuel pin, a 366 spring , turn the fuel screw in some and also the star wheel , then you can add a hx35, or a hx40 turbo with a smaller exhaust housing I went from a 21 to a 16 then down to a 12 wg housing and so far that is 1 of the best mod's I have done besides the 366 spring I think that should be First on anybody's List of mod's right next to Gauges .
Sold the New stuff to build what I like the most 1985 dodge Crewcab Longbed 4x4 cummin's powered Cruiser . wife's hotrod 2012 jetta SW TDI
and 2013 dodge durango built the way we wanted it .
simplysmn is offline
Is a 12Valve a 12Valve? DieselFarmer The Parking Lot 11 02-04-2010 05:59 PM
new to 12valve dallascrwfrd 5.9L Cummins 12 Valve (1994-1998.5) 1 03-10-2009 03:16 AM
No smoke, 12valve diesel_ram_man 5.9L Cummins 12 Valve (1994-1998.5) 4 03-18-2007 01:35 AM
12valve vs. powerstroke detailman Road Kill, Bench Racing 32 03-02-2007 07:59 AM
98 12Valve Cin's Dodge2 Whats Been Sold 1 05-04-2006 10:11 AM
