B series Valve lash adjustment - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BlowinSmoke, this thread has received 14 replies and been viewed 20899 times.
post #1 of 15 (permalink) Old 04-09-2011, 01:03 AM Thread Starter
BlowinSmoke's Avatar
At this link http://dodgeram.org/tech/dsl/valve_adj/12_valve.html
Where it says "If no barring tool is available, the crankshaft may be turned with a 22 mm socket on the alternator pulley bolt. Rotate the engine clockwise when viewing from the front of the truck. This method turns the engine backwards, so make sure you are adjusting the correct valves."
The valve order on this website would then be backwards correct?
Instead of:
Adjust the clearance for these valves:
#1 - I & E
#2 - I
#3 - E
#4 - I
#5 - E
Then:
#2 - E
#3 - I
#4 - E
#5 - I
#6 - I & E
It would be:
#2 - E
#3 - I
#4 - E
#5 - I
#6 - I & E
Then:
#1 - I & E
#2 - I
#3 - E
#4 - I
#5 - E
Thanks for your help
BlowinSmoke is offline
post #2 of 15 (permalink) Old 04-09-2011, 01:28 AM
Why would you turn the motor backwards. Pin the motor mark the dampener even with the fan belt. One set of valves will be on overlap If it is #1 then #6 is on tdc compression. and you set 124 intake & 135 exhaust, Be sure the pin is removed and set the rest,
Johnp3 is offline
post #3 of 15 (permalink) Old 04-09-2011, 08:38 AM Thread Starter
Just wondering with what it says about not having that barring tool. Does it matter if you turn it backwards?
post #4 of 15 (permalink) Old 04-11-2011, 12:05 AM
bmoeller's Avatar
For setting the valves, it doesn't matter what direction the motor is turned. Backlash in the geartrain won't matter here. Neither does the timing pin. Just watch the rocker arms to know where to stop at for 1 and 6 TDC. Pump timing is a different story.
You turn the engine backwards using the alternator nut because you can't keep tension on the belt and it slips on the pulley. And sometimes need to put a breaker bar in the tension to put more pressure on the belt so it won't slip.
A barring tool would be nice, but not absolutely needed for running the overhead. At least there is plenty of room to use one, and still turn it from the top side and watch things. No coolers in the way (at least on a 5spd truck).
"Obama = Hoax and Chains"
bmoeller is offline
post #5 of 15 (permalink) Old 04-13-2011, 05:06 AM Thread Starter
Right on. Thanks. Any idea where to find one of those nice barring tools?
post #6 of 15 (permalink) Old 04-22-2011, 05:10 AM
um sure?
BBD Performance's Avatar
also a little tip, set your intake to .008" and .015" exhaust, this will start the cam sooner in its lift and take a little longer in its close sequence and will allow faster spool and slightly cooler egt's. DO NOT GO BELOW THIS OR BAD THINGS CAN HAPPEN.
BBD Performance is offline
post #7 of 15 (permalink) Old 04-23-2011, 05:33 AM Thread Starter
Sounds good how about .009 and .016?
post #8 of 15 (permalink) Old 04-23-2011, 05:41 AM
um sure?
that works too
one truck at a time www.bigbaddieselperformance.com
post #9 of 15 (permalink) Old 04-23-2011, 04:29 PM
Seeing as most engines nowadays the set gets tighter, how about .010 and .020, that has worked for a lot of years.
Johnp3 is offline
post #10 of 15 (permalink) Old 04-23-2011, 04:38 PM
um sure?
in a High HP rig .008" and .015" will improve performance in a stock truck then yes .010 and .020
valve lash cat 3406e buffalobob Medium and Heavy Duty 12 05-08-2011 02:19 PM
24v standard procedure - valve lash adjustment triton 5.9L Cummins (2003-2007.5) 0 02-09-2009 07:57 PM
Valve lash adjustment Hardline 5.9L Cummins (2003-2007.5) 10 03-18-2008 11:52 AM
Valve Lash racehauler 1994-2003 7.3L Power Stroke 6 11-10-2006 03:49 PM
6.0's need a valve lash ajustment? fastback4 2003-2007 6.0L Power Stroke 4 11-10-2006 02:38 PM
