Where should I send my injections pump? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Lonesome7.3, this thread has received 62 replies and been viewed 6568 times.
post #1 of 63 (permalink) Old 05-29-2011, 11:56 PM Thread Starter
This is my first Cummins 12V and I have no idea where to go or where to send stuff. I think my injection pump is bad and I am hoping sending it off to be rebuilt is cheaper than buying a new one. While it is getting gone through are there any mods that can be done to give my engine some more output? Who should I send it to? What should I know and what kind of questions should I ask before I send it off?
post #2 of 63 (permalink) Old 05-30-2011, 01:04 PM
Stay away from Penscola Diesel. That place has a very bad rep for rebuilt pumps and injectors..
I haven't heard of any problems with industerial injection.
Schied's is another shop with a good rep.
Most shops limit turning up a pump to around 10% above factory settings. Anything above that they will not warrent.
What is the engine doing to make you think the injection pump is bad???
Philip is offline
post #3 of 63 (permalink) Old 05-30-2011, 08:09 PM
Nadir's Avatar
Have them install the 366 governor spring while they are at it. Best thing you can do to it, and I doubt they have any problem doing it because it's a stock Bosch part.
Truck Pics:
Nadir is offline
post #4 of 63 (permalink) Old 05-30-2011, 11:37 PM Thread Starter
Thanks for the heads up. Some one else suggested I give them a try.
I replaced the lift pump when I found out it was bad with a newer piston driven pump and the engine still will not start.
Thanks for the tip, I will make sure I ask about it. What does the different spring do?
post #5 of 63 (permalink) Old 05-31-2011, 11:55 AM
Nadir's Avatar
The 366 gov spring is a stronger spring that allows the pump to fuel up to 3200 rpm. Stock is like 2200 or maybe 2400.
Truck Pics:
Nadir is offline
post #6 of 63 (permalink) Old 05-31-2011, 04:12 PM Thread Starter
Thanks for the information. Are there any other tips to make this IP a little better?
post #7 of 63 (permalink) Old 05-31-2011, 06:42 PM
Nadir's Avatar
Be careful R&R'ing it.
Truck Pics:
Nadir is offline
post #8 of 63 (permalink) Old 05-31-2011, 10:24 PM Thread Starter
What do you mean?
post #9 of 63 (permalink) Old 06-01-2011, 01:20 PM
Nadir's Avatar
Have you ever taken one off before?
Truck Pics:
Nadir is offline
post #10 of 63 (permalink) Old 06-01-2011, 04:43 PM Thread Starter
Ah, I see. No I have not, however I watched some videos made by dodge on how to remove one. That really helped. They took a lot of the mystery out of it.
can sombody send pic to help me!!!!!!! the mud pits nevada tx 5.9L Cummins 12 Valve (1994-1998.5) 1 03-04-2010 06:28 AM
how do i send a PM here? jr. Medium and Heavy Duty 6 01-26-2010 10:57 AM
Industrial Injections 64mm turbo??? Extended Power 2003-2007 6.0L Power Stroke 46 08-02-2009 01:21 PM
When ya get done with your wheels send em my way! fjh Medium and Heavy Duty 12 03-07-2007 02:10 AM
Should We Send Them Some Help? BROKER The Parking Lot 1 12-13-2005 01:33 PM
