Still will not start, now what? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Lonesome7.3, this thread has received 18 replies and been viewed 3126 times.
post #1 of 19 (permalink) Old 06-01-2011, 09:03 AM Thread Starter
My 6BT still will not start and I have no idea what else to do. I have replaced the lift pump with a piston driven one, removed and blew out the lines, replaced the filter, and cleaned the tank. Fuel is flowing through the system. I bled it just like it is described in this video:
http://www.youtube.com/watch?v=x3UuM...eature=related
Very good information in all three of them. I hear the solenoid clicking when I hit the key and fuel in flowing through the lines to the injectors but the damn thing still will not start. What else is there for me to do?
post #2 of 19 (permalink) Old 06-02-2011, 01:47 AM
bmoeller's Avatar
How many times did you push the primer? On my '97, I usually had to push it maybe upwards of 75+ pumps to bleed it good. Could hear the overflow valve chatter at me. Usually did another 20pumps after if started to chatter at it always popped right off.
Are you actually hearing the shut down solenoid click? Or is it something else? I'd pull the solenoid, and see if it is actually doing its job, or if it is damaged and preventing it from allowing the engine to start.
"Obama = Hoax and Chains"
bmoeller is offline
post #3 of 19 (permalink) Old 06-02-2011, 02:56 AM Thread Starter
I pumped it until the air bubbles stopped coming out of the injector connectors. I am pretty sure I hear the solenoid clicking.
post #4 of 19 (permalink) Old 06-04-2011, 03:27 AM
bmoeller's Avatar
Re-read my post. Plus, there are other relays that will be clicking in the start/run position of the key. Got to check what is going on. I'd lend a hand, but you're about 16hrs away.
bmoeller is offline
post #5 of 19 (permalink) Old 06-04-2011, 03:32 AM Thread Starter
I see what you are saying now.
post #6 of 19 (permalink) Old 06-05-2011, 02:54 AM
If he is getting fuel to the injectors then it is not a shut down solenoid problem.
I would be looking more towards a timing has slipped problem.
Can you check the fuel pressure. I have a pressure regulator valve, the fuel return valve, that has the 1/8 plug in it. Tpo front inside of injection pump, if you have the P7100 pump, the one with the ball visible is useless, The one with the 1/8 plug you can buy a new regulator valve. Then a new sealing washer and remove the banjo bolt from the fuel inlet and replace it with the old regulator, take out the plug, the spring and the ball. Insert a fitting and a preasure guage.
You may have to grind a bit of the head away to get the old regulator out.
Works for me!
Johnp3 is offline
post #7 of 19 (permalink) Old 06-05-2011, 05:59 AM Thread Starter
I am lost on that. Do you have any photographs?
post #8 of 19 (permalink) Old 06-05-2011, 03:41 PM
No but the banjo bolt for the return is the same as the input. if the return banjo bolt has a 1/8 plug in it you can make a fuel pressure test fitting.
Johnp3 is offline
post #9 of 19 (permalink) Old 06-05-2011, 10:25 PM Thread Starter
That part I get. But when you mentioned altering a fitting I am not sure I am tracking.
post #10 of 19 (permalink) Old 06-05-2011, 10:35 PM
If you want to test the fuel pressure, that is a cheap and easy way of doing it.
Johnp3 is offline
Strange Cold start/no start/start changexlt 2003-2007 6.0L Power Stroke 7 12-23-2008 09:00 PM
Fresh Start: needing advice to start off on the right foot. MoparChallenger 5.9L Cummins (2003-2007.5) 22 03-07-2008 01:10 AM
Rough start and white smoke at cold start? bassn_07 2003-2007 6.0L Power Stroke 11 03-02-2008 10:57 PM
04-17-13 Hard Start Or No Start - Gpcm Connector Service Kit Available - 6.0l Engine Squatch Ford Oasis requests 0 03-23-2007 11:55 AM
CRANK NO START, HARD START, RUNS ROUGH AT IDLE - 6.0L 2005 F, E-Series,and Excursion PSDPlayer 2003-2007 6.0L Power Stroke 0 10-08-2005 07:32 AM
