Axle seals and Hubs leaking - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BlowinSmoke, this thread has received 4 replies and been viewed 1090 times.
post #1 of 5 (permalink) Old 09-16-2011, 06:38 PM Thread Starter
BlowinSmoke's Avatar
My axle seals and hubs are leaking, they have that wonderful grease oil ring going on at the seal. I'm very meticulous putting things back together and this just puzzles me. Was wondering if you guys had an idea or a fix to this, thanks guys.
BlowinSmoke is offline
post #2 of 5 (permalink) Old 09-18-2011, 07:57 AM
There is a product called a 'seal saver', it is a sleeve that covers a rough sealing surface, another way is to make a shim that offsets the seal so it does not run in the wear grove on the houseing.
Not setting the seal in plane will wear them rapidly and denting the metal will often cause a leak.
For pulling a seal the easy way is to remove all but the outer nut that you thread on 2-3 threads and then use the hub like a slide hammer to pull the seal - the inner bearing and seal are left hanging on the spindle with no damage so you can wash them and look for the cause of a leak - often a nick in the seal lip but sometimes the plastic is hard and cracked. Dirt at the seal lip is most common and it will wear a place on the spindle that will wear the seal rapidly, hence the seal saver.
81 Isuzu /C223na, 5spd
keydl is offline
post #3 of 5 (permalink) Old 09-22-2011, 01:41 AM
bmoeller's Avatar
Check/clean the axle vent first, and go from there.
"Obama = Hoax and Chains"
bmoeller is offline
post #4 of 5 (permalink) Old 09-23-2011, 10:10 PM Thread Starter
Thanks man I'll have to look into that product and find some. Its kind of annoying when you take it all apart and think you've fixed it just to find it a couple of weeks later leaking again.
post #5 of 5 (permalink) Old 09-24-2011, 08:18 AM
bmoeller is right on the air vent that holds the brake tee on the housing. Best is running a vent hose up the firewall, it is worth replacing if it is a 2wd with no hose and just tucking the end in the frame as the factory does.
A plugged vent will leak when the rear end warms up but not usually on short hops around town, damaged seal surfaces are pretty much time/miles related.
keydl is offline
D60 Axle Seals PhilipR General Dodge Discussion 0 06-08-2010 10:16 PM
inner seals on front axle sirthomas 1994-2003 7.3L Power Stroke 9 03-28-2009 01:50 AM
Front Axle seals. Macktruckdriver 1994-2003 7.3L Power Stroke 8 02-27-2008 12:15 AM
front axle seals Diesel Fanatic 5.9L Cummins (1998.5-2002) 2 07-03-2007 08:17 PM
Rear axle seals Duke Medium and Heavy Duty 27 03-16-2006 06:44 PM
