Block heater - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dartman366, this thread has received 4 replies and been viewed 1600 times.
post #1 of 5 (permalink) Old 11-01-2011, 06:01 PM Thread Starter
Block heater
My 93 diesel dually is equipped with what I believe is a factory block heater, winter is comming and the truck probably won't be used much untill spring, unfortunately it will have to be parked outside as I have no room to park it inside yet,my question is,,would it be advisable to leave the heater plugged in for extended lengths of time like months at a time? I fully intend to start the truck and warm it up on a weekly or bi weekly basis, never had a vehicle that had a block heater, so all comments are welcome.choppingwood
dartman366 is offline
post #2 of 5 (permalink) Old 11-03-2011, 04:44 PM
There is no need to leave the unit plugged in, that just waists power. If you have a regulated battery charger, put it on one a month and start it once a month. I would put on a new fuel filter and change the oil before you shut it down. Even give it a real good washing, and do a valve set. Starting it weekly will not do anything positive to the engine unless you are going to work it for an hour or more. You only want to plug it in for a couple of hours before you start it, and it should not be above 45 degrees F. Cleaning the battery connections, and washing the batteries, will stop a lot of battery drain.
Johnp3 is offline
post #3 of 5 (permalink) Old 11-03-2011, 06:22 PM
Combat Trucker
hillbilli's Avatar
Also make sure you have #1 diesel and perhaps an anti-gel in the fuel system before letting it set. Wouldnt want summer diesel gelling in your tank.
07 Ram 2500 5.9 Megacab
96 k2500 Extcab 6.5TD vin F NV4500 3.73 245k miles
07 Hemi Durango
03 Ram 2500 (Gone but not forgotten)
hillbilli is offline
post #4 of 5 (permalink) Old 11-14-2011, 11:05 AM
bmoeller's Avatar
Do as the other 2 have suggested.
Only need to plug it in maybe 3hrs before you want to start it. Pull the battery out and put it in the heated garage (if you have one), and keep it hooked up to a trickle charger.
If you won't drive the truck when you start it, don't bother starting it. Won't help any. If you won't work it and run it up to temp, you won't burn off any condensation anyhow.
"Obama = Hoax and Chains"
bmoeller is offline
post #5 of 5 (permalink) Old 11-16-2011, 02:53 PM Thread Starter
Thank's guy's I do have a trickle charger and I have the anti gelling addative and will put that in when I go and fill the tank and get ready to park her.
Block Heater Jay21 1994-2003 7.3L Power Stroke 6 11-25-2010 01:46 PM
block heater and magnetic oil pan heater DZL BULL 2003-2007 6.0L Power Stroke 3 12-14-2009 01:20 PM
Block heater? MART5.9 5.9L Cummins (2003-2007.5) 15 04-14-2009 12:27 AM
Block Heater rsa133 General GM Truck Forum 1 04-03-2007 12:21 AM
block heater on 06 FSTDZL 5.9L Cummins (2003-2007.5) 10 02-21-2006 05:02 PM
