Tranny cooling on an 89 6BT powered Dodge ???????? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Lonesome7.3, this thread has received 6 replies and been viewed 1686 times.
post #1 of 7 (permalink) Old 03-18-2012, 07:09 PM Thread Starter
I have a 89 or 9? Dodge with a Cummins 5.9. This is my first one and even though it has been sitting in the yard for a while I have not messed with it much. I went out to pull the tranny cooler and lines for my other Dodge with a gasser. I noticed it had lines running in different directions unlike my old gasser. The lines ran to a canister on the passenger side of the engine. Then a line from that ran to the front of the engine. Then of course there is a return line and the lines that ran to the cooler in front of the radiator. Is that canister on the side of the engine a transmission fluid cooler? If so, how does it work? If it is I am assuming it works a lot like the oil cooler on my 7.3 Stroke.
post #2 of 7 (permalink) Old 03-27-2012, 01:10 AM
It is a liquid to oil cooler. The cooler is plumbed into the engine cooling system. The other half is trans fluid.
It is a lot better cooler than a air to to liquid cooler.
Philip is offline
post #3 of 7 (permalink) Old 03-27-2012, 12:08 PM Thread Starter
Thanks for cleaing that up. What do you think would be a good way to clean it with out damage.
post #4 of 7 (permalink) Old 04-01-2012, 01:09 AM
Those cooler will take about anything for cleaning. I would just hit it with some brake cleaner.
Philip is offline
post #5 of 7 (permalink) Old 04-01-2012, 01:19 AM Thread Starter
I should have neough fo that lying around.
post #6 of 7 (permalink) Old 04-03-2012, 04:31 PM
I buy that stuff by the case. I never run out.
Philip is offline
post #7 of 7 (permalink) Old 04-03-2012, 08:11 PM Thread Starter
I use to,but now that I have a very freaking tiny garage i half to buy stuff as I need it.
I need some guidance on getting this old Cummins powered Dodge running again Lonesome7.3 5.9L Cummins (Pre 1994) 4 01-25-2011 04:51 PM
tranny rebuild kits! need help asap tranny is shot...f'in dodge auto trans blksmk 5.9L Cummins 12 Valve (1994-1998.5) 5 12-26-2008 10:55 PM
tranny cooling system's need some help ?? strokedout_07 1994-2003 7.3L Power Stroke 8 10-22-2007 04:17 PM
Tranny for 01 Dodge AUGSX Supporting Vendors Forum 0 01-17-2007 12:06 AM
Dodge Tranny lukesdiesel 5.9L Cummins (2003-2007.5) 3 12-04-2005 09:23 PM
