Cummins powered Ford - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by countryboy88, this thread has received 33 replies and been viewed 3784 times.
post #1 of 34 (permalink) Old 03-06-2006, 03:39 AM Thread Starter
In the passing lane
countryboy88's Avatar
Send a message via AIM to countryboy88
Iam thinking about droping a 91 12v in to my 90 F-250 4x4. I have heard that the swap is basicaly a bolt in swap. Anything else that I should know about
Truck: 1990 Ford F-250 5.0 EFI, 4x4 , Longbed, 5 speed w/ Hurst shifter, K&N FIPK, Line-X Bed liner, Ford Racing Valve Covers, 2 1/2 in exhaust w/ 4 inch SS tips, A pillar pod filled with Autometer Pro Comp Ultra Lites , Custom switch box w/ 5 switch panel, and more to come
In The Passing Lane
countryboy88 is offline
post #2 of 34 (permalink) Old 03-06-2006, 04:19 AM
I've never done the swap, always wanted to though. Keep us posted, it'll be cool. What trans are you gonna use?
post #3 of 34 (permalink) Old 03-06-2006, 04:46 AM Thread Starter
In the passing lane
I was thinking about using the stock trans that is in the 12v, which is a 5 spd. with a new clutch already installed in it. If I do the swap the truck will have stacks,fuel turned up,fuel plate,bigger injectors&turbo,and most likely a intercoller since I dont know if the donor truck would have one or not. Any other ideas.
In The Passing Lane
post #4 of 34 (permalink) Old 03-06-2006, 10:48 AM
if you use the dodge getrag 5spd then you either need to use the dodge transfer case or use a divorced transfer case
DBogo is offline
post #5 of 34 (permalink) Old 03-06-2006, 01:21 PM
haz-mat19's Avatar
That sound like a cool project. Once you start it get some pictures up so we can see it. There is a web site dedicated to that exact swap, I will see if I can find it. Or someone my put it up faster.
'01 xcab 4x4,Suncoast by Mike L. Goerend triple, edge III, AFE stage II, HTT 62/12, FASS, and other stuff
haz-mat19 is offline
post #6 of 34 (permalink) Old 03-06-2006, 02:58 PM
Here ya go, good luck.
www.fordcummins.com
imported_Smokem is offline
post #7 of 34 (permalink) Old 03-06-2006, 11:28 PM
www.fordcummins.com
that site will have everything that you need to do the swap
DBogo is offline
post #8 of 34 (permalink) Old 03-07-2006, 12:13 AM Thread Starter
In the passing lane
I was thinking about using the dodges transfer case or the one that is in my truck now. By what the Fordcummins site all that I would have to do is to get an adapter from avanced adapters to use my trans and t case. Any ideas on what I should use. The site realy has me thinking about doing the swap. It is way cheaper than what a newer truck would be. The swap is cheaper than I thought it would be. If and when I do the swap I will be sure to post pics of it.
In The Passing Lane
post #9 of 34 (permalink) Old 03-07-2006, 12:17 AM
definatly go for the swap it aint all that hard and the results are the best
DBogo is offline
post #10 of 34 (permalink) Old 03-07-2006, 12:24 AM Thread Starter
In the passing lane
What for mods should I do if I choose to do the swap. I plan on having dual stacks,fuel turned up,bigger injectors&turbo,intercooler( what would work for one). Any other ideas.
In The Passing Lane
