Need help asap, 91 cummins. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 00turboPSD, this thread has received 19 replies and been viewed 6115 times.
post #1 of 20 (permalink) Old 03-08-2006, 05:02 PM Thread Starter
My friend has a 91 cummins 12 valve, he said he was driving down the highway at about 65 and it just cut off on him. So far he has checked to see if there is fuel pressure and there is, and he says he has checked the air filter and its not dirty. I don't know a whole lot about 12 valves, so if anyone with some knowledge could please help us out that would be great. Thanks. He also said he changed the oil the night before if that makes any difference.
00turboPSD is offline
post #2 of 20 (permalink) Old 03-08-2006, 05:12 PM
Check the two wires running to the fuel shutoff solenoid, sometimes the crimped ends get corroded or loose. If they lose connection the plunger will cutoff fuel to the injection pump. It is the solenoid just below the fuel power fuel adjustment screw. http://www.turbodieselregister.com/u...d=2498&width=0
imported_Smokem is offline
post #3 of 20 (permalink) Old 03-08-2006, 05:27 PM Thread Starter
Well he says that he has loosened a few injectors and turned over the engine, and fuel still comes out. He also says he drained the fuel filter to see if there was water. He repurged the system and says it still wont fire, it will turn over but no fire. Ill tell him about the wires to see if thats the problem, but he says he has fuel so it doesn't make sense to me.
post #4 of 20 (permalink) Old 03-08-2006, 05:30 PM
What about the relays for that solenoid? Check them as well for power in and out....follow wires from solenoid back to relays......
RacinDuallie is offline
post #5 of 20 (permalink) Old 03-08-2006, 05:33 PM
The fuel gallery should still have fuel, which is why he has fuel at the injectors. I had a '91 that would not start after I had turned the pump up, I bleed the injectors and everything else I could think of and there was fuel. It turned out that I didn't connect one of the fuel shutoff solenoid wires. I wish I would have noticed, it would have saved me about 2 hours.
post #6 of 20 (permalink) Old 03-14-2006, 01:29 AM
certified smoker
i have a 1992 dodge 12 valve that did the same thing all i had to do was replace the crankshaft sensor. It is located on the top side of the crankshaft balancer and plugs in on the top of the engine by the front valve cover. hope i was some help.
certified smoker is offline
post #7 of 20 (permalink) Old 03-14-2006, 01:39 AM
you may want to tell your friend to check the crankshaft sensor. i have a 1992 12 valve that did the same thing. the sensor is located on the top of the crankshaft balancer. it then plugs in on the top side of the engine by the front valve cover. hope i was a help to you and your friend. certified smoker
post #8 of 20 (permalink) Old 03-20-2006, 03:56 AM Thread Starter
Thanks alot, I bet the sensor is his problem, if its the same as the ford, it just dies out of nowhere, like mine did twice in one year, that sure does get expensive after a while. Any numbers on what a new sensor costs for the 12 valve? Thanks alot!
post #9 of 20 (permalink) Old 03-25-2006, 12:52 AM
St
I am actually the owner of this truck, I had my friend post before i was a member. Tonight i pulled apart the shut off solenoid and took out the spring and diaphram to see if it would work. I talked to a service guy at cummins today and that is what he told me to do. When i cranked it, it would almost start but wouldnt fire still. Gets closer than before but still nothing. Does anyone have anymore ideas? Oh, since my truck is a 91, i dont have a crankshaft position sensor like previously thought so, that wont work. Also, thanks for everyones help before.:shrug:
rfishbone is offline
post #10 of 20 (permalink) Old 03-25-2006, 10:37 AM
had 91 also. check them 2 wires on fuel pump. right below turn up screw. clean and re-crimp. should light up
beamwalker is offline
