Axle swap - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by tommu, this thread has received 1 replies and been viewed 1397 times.
post #1 of 2 (permalink) Old 03-07-2013, 02:46 PM Thread Starter
Axle swap
Good Morning, I have a 92, 2w, d250,automatic. The rear end 9 (dana 70, 3.54 ratio. posi.)was clunking AND GOT WORSE AND IS NOW GRINDING BAD AND THE TRUCK BARELY MOVES. I found a 2001 2w, dana, 3.54, posi.,axle disc. with drum e brake axle to replace it.
Will it fit if I cut off the shock mount brackets and use my old u bolt plate for the shock mount (the 92 axle is 42", the 2001 is 43" where the springs mount)?
Will the drive shaft spline match?
Will I have to shorten the drive shaft?
Will I need different rims (17") to accept the new style hubs?
Are the stud and lug nut the same (thread pitch)?
Any other problems or fabrication you can think of?
Thank You
tommu is offline
post #2 of 2 (permalink) Old 03-08-2013, 03:33 AM
Aimless Wanderer
Thank You
Much more work and cost than benefit to be gained. Get a 1993 or older axle, reuse the sure grip limited slip differential with new bearings and clutches if not in the donor axle.
Backslap is offline
04 to 06 axle/suspension swap FSD General Ford Truck and Excursion 36 04-13-2009 04:25 AM
axle swap 2tonePSD 7.3L and 6.9 IDI (Pre 1994) 2 01-18-2009 07:14 PM
97 250 frt axle swap to 350 axle just visiting 1994-2003 7.3L Power Stroke 7 02-11-2008 04:49 PM
Straight axle swap powerstroker97 General Ford Truck and Excursion 14 05-08-2007 09:57 PM
Axle swap 2insane 4X4 Offroad Forum 32 10-12-2006 02:33 PM
