Mods for a 1st gen - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by countryboy88, this thread has received 20 replies and been viewed 1982 times.
post #1 of 21 (permalink) Old 03-28-2006, 04:10 AM Thread Starter
In the passing lane
countryboy88's Avatar
Send a message via AIM to countryboy88
Mods for a 1st gen
I want to know what mods can be put on a 1st gen motor. I want to know what you guys have, so when I swap a 1st gen in to my F250. I want an idea of what I can do.
Truck: 1990 Ford F-250 5.0 EFI, 4x4 , Longbed, 5 speed w/ Hurst shifter, K&N FIPK, Line-X Bed liner, Ford Racing Valve Covers, 2 1/2 in exhaust w/ 4 inch SS tips, A pillar pod filled with Autometer Pro Comp Ultra Lites , Custom switch box w/ 5 switch panel, and more to come
In The Passing Lane
countryboy88 is offline
post #2 of 21 (permalink) Old 03-28-2006, 05:14 AM
well is it a early first gen you know rotarty pump(89-93) or a late 1st gen (94-98)
robert
out
alldiesels is offline
post #3 of 21 (permalink) Old 03-28-2006, 10:58 AM
1st gen is 89-93 whick is a VE rotory pump 89-91.5 is non-intercooled, 91.5-93 is intercooled both with the VE pump, 94-98.5 is a second gen which is a inline P7100 pump, if you want high hp the P7100 is the pump to have
DBogo is offline
post #4 of 21 (permalink) Old 03-28-2006, 03:48 PM
dbogo your right i don't know what i was thinking last night, but on a side note i have seen 1 rotary pump truck lay down some good hp and some crazy times, and i looked to make sure it was still rotarty pump
robert
out
post #5 of 21 (permalink) Old 04-05-2006, 05:59 PM
I assume that you are talking drag racing. What would be considered crazy times? And how much HP?
Just curious
rockjeep73 is offline
post #6 of 21 (permalink) Old 04-05-2006, 10:41 PM
he laid down well over 400hp and like 13.2's with a excab at 5k feet and it was a STICK, i about **** my pants
robert
out
post #7 of 21 (permalink) Old 04-07-2006, 06:08 AM Thread Starter
In the passing lane
I was looking at swappinng in a 93 motor. If I swap the 93 in would the P7100 pump be able to be swapped on the motor. What I was planning on
POD Injectors
Intercooler
Bigger Turbo
5 or 6 inch miter cut stacks
Water or Methanol injection
High Performance Fuel Pump
Air filter
Guages
Fuel Pin (if it woud work on the 93 motor)
Any other suggestions
In The Passing Lane
post #8 of 21 (permalink) Old 04-07-2006, 10:56 AM
yea that P7100 can be swapped onto a 1st gen motor its not terrably hard and you wouldnt get a fuel pin if you put the P7100 on you would get a plate, the fuel pin is the equivalent of a plate in a VE
DBogo is offline
post #9 of 21 (permalink) Old 04-08-2006, 05:57 AM Thread Starter
In the passing lane
Ok thanks. Was there anything that you would suggest putting on the motor.
In The Passing Lane
post #10 of 21 (permalink) Old 04-08-2006, 11:03 AM
the P7100, injectors (POD's), fuel plate (0 or 100), turbo (HX hybrid, HX40, S300...), filter (AFE, BHAF), guages (diprocal, autometer, isspro), intercooler bigger is better, thats about it it depends how crazy you want to go with it
DBogo is offline
