91.5 computer - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by danhousjr, this thread has received 5 replies and been viewed 1452 times.
post #1 of 6 (permalink) Old 12-30-2008, 01:13 AM Thread Starter
91.5 computer
About a week ago my speedometer, overdrive, and heaters quit. i took it to have it scanned today and he said the computer wouldnt communicate meaning it was dead..he couldnt locate one but did find somewhere to send it and have it rebuilt for about 300 bucks..does that sound about right? Anybody have one for sale? part #55008911..thanks
danhousjr is offline
post #2 of 6 (permalink) Old 12-30-2008, 04:28 AM
The 91.5 is its own model. The truck didn't use a crank position sensor. The 92/93's did.
That price as about normal for a rebuild from what I have seen.
Philip is offline
The Following User Says Thank You to Philip For this addition to TDG:
danhousjr (12-30-2008)
post #3 of 6 (permalink) Old 12-30-2008, 10:03 AM Thread Starter
thes said about 80% chance it could be rebuilt..
post #4 of 6 (permalink) Old 01-02-2009, 09:52 AM
Is it possible to install a crank position sensor on a '91.5 truck? I really want to install a factory tach on my truck, and they require the CPS. Does anyone offer a CPS that I can install on my truck, and make a factory tach work?
Thanks
'91 1st Gen is offline
post #5 of 6 (permalink) Old 01-06-2009, 04:04 PM
I dought if the 91.5 PCM has that part of the program to read a TPS signal. I also don't know if the wiring harness has the tach provision built into it. I haven't been under the hood of one to check it out.
The factory tack needs a 5 volt signal. You could rig up a magnetic pick and tap off the PCM 5 volt feed wire. That would be a stand alone setup. It wouldn't go threw the PCM. The tack would still work.
Philip is offline
post #6 of 6 (permalink) Old 01-09-2009, 08:36 PM
I have 2 91.5's and neither has the tach harness.
91 W250, rusty POS, no afc, PODS, AM FP gauge, Isspro boost + pyro, 91.5 W350
921stgen is offline
overhead trip computer fix camojeeper Ford - Modification instructions, Product installs and Tech Articles 7 10-06-2010 06:57 PM
Computer Simulation of a Drag Race... ernesteugene Drag Racing 7 12-31-2008 09:12 AM
Computer Question... Jeffybuilt 5.9L Cummins (1998.5-2002) 2 12-25-2008 01:39 PM
Computer Fault Codes pt2 countryboy88 7.3L and 6.9 IDI (Pre 1994) 0 12-23-2008 12:37 AM
Computer Fault Codes pt1 countryboy88 7.3L and 6.9 IDI (Pre 1994) 0 12-23-2008 12:36 AM
