ready to spend some money - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by alldiesels, this thread has received 20 replies and been viewed 1794 times.
post #1 of 21 (permalink) Old 04-05-2006, 03:42 AM Thread Starter
Ok guys, i know i have talked about this crap before but i am ready to do this now so tell me what you think. My cummin is my daily driver but i want it to be able to hold it's own, right now all i have is exhaust, intake and turned up pump, what i want to know is are POD injectors the best to get??? Should i do a fuel pin?? where can i get a 4k or 4200 rpm GSK because i have a 3 speed and need to be able to run it down the 1/4? what do i need to do for valve springs and where can i get them?? what is the best cheep rout to go on a turbo?? and does anyone make anything to beef up my 3 speed?? i am told it is stronger than the 4 speed auto's is that true?
sorry for all the ?'s
robert
out
alldiesels is offline
post #2 of 21 (permalink) Old 04-05-2006, 05:48 PM
I would go with POD's, unless you want to spend a lot more money and gain a little more power by going with some custom EDM's. With the POD's you are going to need the injector adapter tips which you can also get from Piers. I would just grind your stock fuel pin with the direction of others. If you plan on high RPM than you will want to get a set of 12 60lb. valve springs, I got mine from Piers for $110. For the governor spring, you can get it through any Bosch dealer but the 4200 will have to come straight from Bosch in Germany, here is the part # 1 464 650 354. I would call up HTT for your turbo needs, the best cheap route would be to do there stage 3 on your stocker, somewhere around $200 and it uses the 60mm HX40 compressor wheel combined with the center section, exhaust wheel, and housing from your h1c.
http://www.htturbo.com/dodge/index.html
http://www.piersdiesel.com/DodgeProducts.htm
rockjeep73 is offline
post #3 of 21 (permalink) Old 04-05-2006, 06:13 PM Thread Starter
thanks, you have been a big help, but about the trans, i know your running a stock 3-speed like me but do you drive yours at all or just race it??? And do you have part #'s for your slicks and rims?
robert
out
post #4 of 21 (permalink) Old 04-05-2006, 06:36 PM
robert
out
Yes I am still running the bone stock 3 speed, trans upgrades were next on the list before it melted a piston. The truck was owned by my brother and was driven every day and raced every other weekend, until he cooked it. I now own it and I just bought another set of pistons and im gonna rebuild the motor. Im still not sure where im heading with the truck so I cant tell you what im going to do to the tranny yet, probably replace it with a fully built OD tranny if I go all out, if not it will more than likely just get a valve body and converter.
The tires are here. They are the 31 x 13.5 - 15. Part # 522-17790QTP
http://www.jegs.com/webapp/wcs/store...egory_rn=36690
Rims are here. 15x10.
http://store.summitracing.com/partde...5&autoview=sku
post #5 of 21 (permalink) Old 04-05-2006, 06:44 PM Thread Starter
Thanks a bunch, any clu why he melted a piston???? Now i know i have to do the valve springs but what do they do for me? and how hard are they to install? show i replace the headgasket? do i need to do studs??
robert
out
post #6 of 21 (permalink) Old 04-05-2006, 06:48 PM Thread Starter
and 8 lug 6.5 inch will be right for my 90 250 2wd?
post #7 of 21 (permalink) Old 04-05-2006, 06:51 PM Thread Starter
1 more thing, HTT's site states that that stuff will only work on a Inter cooled truck, do i have to intercool mine?
robert
out
post #8 of 21 (permalink) Old 04-05-2006, 06:56 PM
Yes, the rims will fit.
The stiffer valve springs will allow you to run higher RPM without worry of the valves floating. You can get a spring compressor and change the springs out without pulling the head. Your HG "should" be OK, but head studs are a GOOD idea. Just be careful with your timing, the more timing the harder on the HG.
I dont have a positive answer yet on my motor. Could have been an injector popping to early. Could also have been from detonation from a lot of methanol and a lot of timing. Just not sure yet.
post #9 of 21 (permalink) Old 04-05-2006, 07:01 PM
I believe that they say it will only work on the intercooled trucks is because they have a cast elbow that attatches to the compressor outlet which hooks up to the tube that goes to the intercooler. The compressor housing that they supply you with has a flange on it with a lip that a v-band style clamp goes around to attach the cast elbow. All I did was grind off the 1/4" tall lip that goes around the compressor housing outlet in order to use a silicone hose to attach it to my intake horn.
post #10 of 21 (permalink) Old 04-05-2006, 07:02 PM Thread Starter
great, so am i going to have to intercool my truck???
robert
out
