Question? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Ole JIM, this thread has received 7 replies and been viewed 1468 times.
post #1 of 8 (permalink) Old 12-30-2008, 07:42 AM Thread Starter
Smile Question?
as most members know I own a 90 Dodge Diesel hers my question--in looking over other older Dodges I noticed they all have two Batteries-mine only has One! located in front on the drivers side--the ones I saw have another battery located on the passangers side--I*M Not running my Dodge during this Winter--here in the Northeast they use Salt & Chems on all the highways & vehicles Rust Out --very fast-- so MY Dodge will stay in storage until Spring & to my question?? can? & How? do I install a second battery & where? do the Cables Run? any assistance Appricated!--THANKS! Ole JIM-
Ole JIM is offline
post #2 of 8 (permalink) Old 12-31-2008, 07:29 PM
********* and Mafia #90
Bcarriveau's Avatar
Just hook another battery up parallel. so batt 1s + goes to batt2s +, batt1s - goes to batt2s -. simple as that. mount it where you want, use a nice size battery cable as well
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #3 of 8 (permalink) Old 01-02-2009, 01:24 AM
2nd Gen Guru
Mopar1973Man's Avatar
As for where to mount I'm not sure but I'll give you this...
The wiring is like Bcarriveau said...
Positive -> Positive -> Starter
Negative -> Negative -> Ground
These trucks can draw upwards of 700 AMPs to start on a cold day...
Mopar1973Man is offline
post #4 of 8 (permalink) Old 01-02-2009, 04:49 AM Thread Starter
Smile Second Battery hook up?
THANKS! Bill & Michael--Appricate IT!!--Ole JIM--
Ole JIM is offline
post #5 of 8 (permalink) Old 01-02-2009, 09:39 AM
If you aren't going to be running it in cold weather, there is really no reason to install dual batteries, in my opinion.
'91 1st Gen is offline
post #6 of 8 (permalink) Old 01-02-2009, 01:20 PM
2nd Gen Guru
He's got a point...
But the life span of a battery is effected anyways... Look at this...
Starter Load - Between 350 to 700 AMPs
Grid Heater Load - Between 95 to 190 AMPs
Dual Battery
Battery 1 (700 CCA) + Battery 2 (700 CCA) = Total 1,400 CCAs
Single Battey
Battery 1 (700 CCA) = Total 700 CCAs
With a dual battery system you reducing the hit to the bbatteies in half but a single battery need to put out everything it got on a cold startup. My buddy in Riggins, ID had a 92 with a single battery and it struggles even on cool mornings to twist... But once warm is fine starts easy...
post #7 of 8 (permalink) Old 01-03-2009, 02:33 AM
BlowinSmoke's Avatar
Not to sure if it makes a difference. I'm out of washington in the sound area and I've never run into a problem turning over my truck and it runs a single battery. Ive had the truck start on 14 degree mornings and its done fine, no problems with the battery yet.
BlowinSmoke is offline
post #8 of 8 (permalink) Old 01-10-2009, 04:35 AM
The first gens only run one battery stock... Slap a Group 31 battery in there with the highest CCA you can find and you will be fine, the one I have in my 92 is 1100CCA all by itself. I do plan to add a second one as I deal with -40 now and then and I do plow with the truck...
Heck, I ran the same battery by itself in my 6.9 Ford without any troubles.
DD/Tow Pig: 92 W250 Reg Cab LE, CTD/5 Speed, loaded, all the goodies, A/M guages, all the screws turned, 33 psi, still need a 3200 spring...
Play truck: 86 F250 reg cab, 4x4, D60/10.25 460/T19, 38.5's....
Other stuff:
89 W250 CTD/5 speed
86 F250 4x4, 6.9/4 speed
82F100SWB is offline
EGR question shiner1836 6.7L Cummins (2007.5-2011) 6 01-09-2009 11:24 PM
4X4 question Rosco 2003-2007 6.0L Power Stroke 12 01-08-2009 06:20 AM
6.0 guy with a 7.3 question LovinPSDs 1994-2003 7.3L Power Stroke 13 01-05-2009 01:41 AM
Turbo Question 9612vinva 5.9L Cummins 12 Valve (1994-1998.5) 24 01-02-2009 03:01 AM
