Timing question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by City Guy, this thread has received 6 replies and been viewed 2160 times.
post #1 of 7 (permalink) Old 09-19-2014, 08:26 PM Thread Starter
Timing question
Is it possible for the timing gear to jump time (enough room in the case) when replacing the IP? Or is that impossible? Reason I'm asking is I replaced my IP and now it seems I can get enough advance to make it run right. Smoke when cold runs a little rough, but with KSB "on" it runs great.
1990 Dodge 250 5.9 12V 727 auto Bone stock 256,000 miles when the odometer quit working a couple years ago. Needs paint bad, Az. sun baked it off. Afraid to re-paint it, fear it will get stolen and took to Mexico.
City Guy is offline
post #2 of 7 (permalink) Old 10-03-2014, 04:33 PM
It can be jumped a tooth without removing the cover.
Philip is offline
post #3 of 7 (permalink) Old 10-14-2014, 08:52 PM Thread Starter
Ok, some say you can't and some say you can. I'm confused.........
City Guy is offline
post #4 of 7 (permalink) Old 10-17-2014, 12:22 AM
With the pump off the gear there is enough room for it to turn one tooth. Most guys that jump the timing a tooth don't pull the cover.
Philip is offline
post #5 of 7 (permalink) Old 12-17-2014, 03:18 PM Thread Starter
Not this one. Finally rounded up a timing gauge (cheap on E-Bay) and checked it. Advanced as far as it would move against the head the IP was at .4mm plunger lift @TDC (data plate marked 1.4mm) pulled the IP and attempted to move the gear, nope won't move messed with it for half hour. Pulled the cover and found the gear was on the stock timing mark "E" advanced it to "C" rechecked it was now at 1.0mm, advanced it another tooth and now at 1.4mm in the center of the adjusting slots. Runs great. EGT down and power up. So at the end of the day if you don't have a timing gauge to see where your at you can only guess where the timing is at.
City Guy is offline
post #6 of 7 (permalink) Old 12-17-2014, 08:32 PM
With a 12 valve the timing is set with the timing plug in the gear and the gate lining up in the window of the pump.
Johnp3 is offline
post #7 of 7 (permalink) Old 12-24-2014, 04:59 PM Thread Starter
It has a VE IP uses a dial indicator.
City Guy is offline
07 cummins isx engine timing question randerson Medium and Heavy Duty 5 12-23-2011 03:46 PM
Question Timing or what ? Tracy 7.3L and 6.9 IDI (Pre 1994) 0 04-20-2010 04:57 PM
Timing question TLadd 6.5L Diesel Engine 11 01-30-2009 12:48 PM
Timing question kc04 5.9L Cummins (2003-2007.5) 3 02-22-2008 09:53 PM
timing question GOAT 5.9L Cummins (2003-2007.5) 3 10-16-2007 06:42 PM
