Bosch P pump conversion - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by j41385, this thread has received 4 replies and been viewed 2318 times.
post #1 of 5 (permalink) Old 05-15-2005, 11:56 AM Thread Starter
I am just thinking of excuses to start a thread, Does anyone know of a way to convert a 1st gen. to a Bosch P pump? A friend of mine said you could. Viva Cummins!
1972 Ford F100, Built 300 inline 6. MSD 6A, MSD Blaster II coil, Ford 9mm Spark Plug Wires,Hedman Header, Dual 2.5" Exhausts with Flowmasters, Offenhauser C series intake, Edelbrock 500cfm Carb, Ross forged 9.5:1 CR pistons, and some headwork.
j41385 is offline
post #2 of 5 (permalink) Old 05-15-2005, 04:10 PM
From what I understand a VE to a P pump is easier than a vp-44 to a P pump.....I'd talk to jeff garmon...he is a P-pump Wizard....But that being said, i watched a !st gen with a VE pump Make 642 Hp on Diesel only at TS performance's event last weekend...
Timbeaux38 is offline
post #3 of 5 (permalink) Old 06-08-2005, 07:01 PM
Ggg
IIRC
1. front cover
2. inj. pump
3. fuel lines to injectors
4. fuel line from lift to inj. pump
Ggg is offline
post #4 of 5 (permalink) Old 06-10-2005, 01:18 AM
The gear housing will have to be changed,this means removal of the cam.P pumps use a different lift pump also
Chriscumminsdiesel
chriscumminsdiesel is offline
post #5 of 5 (permalink) Old 01-26-2006, 06:20 PM
I'm Doing Mine Right Now. It's A Long Task But Doable. You Need The Gear, Housing, Cover Plate, Lift Pump Set Up. Lines. You Have To Convert Your Throttle Linkages. Rewire Your Fuel Shut Off. If You Need Help Just Measage Me And I Can Talk Ya Through It. Not Really Hard Just Takes Time. And Get Your Houseing And Gear From A Junk Yard. New From Cummins Your Over 600 Bucks. I Got All My Stuff For 150
TUSTUD is offline
Playstation 3 APEX320 The Parking Lot 25 01-17-2009 01:36 PM
Quick Oil Question powerstroke2003 The Parking Lot 10 01-05-2009 02:53 AM
Thumnails Silver_Stroker Site Information 2 01-03-2009 10:41 PM
keyed Dalpilot 2003-2007 6.0L Power Stroke 22 09-20-2005 04:20 AM
