Bought another 93 today... One Issue??? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 95psdF250, this thread has received 12 replies and been viewed 1395 times.
post #1 of 13 (permalink) Old 03-14-2008, 04:02 AM Thread Starter
Git-R-Done
Well I bought a one owner 93 dually ext. cab 4x4 5spd with 169,000 miles on it today.
The truck nasty but in good condition other than needing a paint job but I figured for $2650 I could not pass it up.
The only real problem it has is the tranny has no 4th gear and third gear sounds like it is grinding when you push the throttle hard.
4th gear is not even there at all. If you try to find it there is no hole for it and the shifter will just go over to 2nd or reverse.
I ahev had no experiance with one of these dodge trannys so I don't have a clue what would be causing this. Does anyone have any idea what the issue may be??
Thanks,
Darrell
SLAPS Member
1996 F250 Ext. Cab 5spd. Power Stroke
1999 F250 Ext. Cab Automatic 4x4 Power Stroke
1993 RAM 350 Club Cab Automatic Dually Cummins
1993 RAM 350 Club Cab 5spd 4x4 Dually Cummins
95psdF250 is offline
post #2 of 13 (permalink) Old 03-14-2008, 08:25 PM
T.D.G. Mafia Member #88
cumminspride's Avatar
Wow, what a steal! pull the getrag and rebuild the thing. I know very little about the G-trag but sounds like there is some serious issues inside that case. For the money I'd just get it rebuilt or order a remaned and swap it.
cumminspride is offline
post #3 of 13 (permalink) Old 03-15-2008, 08:58 AM
gr8whitectd's Avatar
if you have the time and funds i would definatly swap up to nv4500 or ? the getrags just dont last.
gr8whitectd is offline
post #4 of 13 (permalink) Old 03-15-2008, 07:02 PM
He has an automatic if you read his sig. But on a side note, the getrag is actually a very good tranny. I havent had an issue with mine, just like 1000 others who will agree.
rbrettctd is offline
post #5 of 13 (permalink) Old 03-16-2008, 12:29 AM
The one in the sig is an auto but the thread is "I bought another 93 today". He stated that it's a 5spd. But I do agree when driven properly the getrag is better than the 5thgear nut issue.
post #6 of 13 (permalink) Old 03-16-2008, 06:18 AM Thread Starter
Git-R-Done
Yeah the new one I just bought is a 5 spd. I am going to pull it next week and have a buddy tear it down and then we will go from there.
SLAPS Member
post #7 of 13 (permalink) Old 03-16-2008, 07:13 AM
The 3-4 syncro is broken, probably a mainshaft and 3-4 syncro and a full set of bearings to repair.
There is metal drifting in the trans oil so check the gear faces very close for pinning of the pieces on the surface, they scrape with little problem but cause lots of wear if left.
keydl
81 Isuzu /C223na, 5spd
keydl is offline
post #8 of 13 (permalink) Old 03-16-2008, 04:45 PM
284
Darrell, the main problem I see is that you own a psd.
But that can easily be rectified.
284 is offline
post #9 of 13 (permalink) Old 03-19-2008, 01:30 PM
Biggest killer of the the Getrag is LUGGING it. (Too high a gear for the forward speed) Keep the engine at or near its optimum RPM and it'll last darn near forever. Learned that lesson the hard way...
shoot4fun is offline
post #10 of 13 (permalink) Old 03-20-2008, 06:07 AM Thread Starter
Git-R-Done
Well I am looking for one now and I am finding they are a little difficult to find. Does anyone have any suggestions where to look??
SLAPS Member
