turbine housing - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by exoticsrnw, this thread has received 1 replies and been viewed 865 times.
post #1 of 2 (permalink) Old 03-16-2008, 05:34 AM Thread Starter
turbine housing
im doing a conversion for a freind of mine the motor is a 1990 12v i know that the turbine housing is a 18cm but cant i switch it out to the 16cm and is it the same one as the 16cm housing im running on my 97 12v
thanks
trever
90 ford f350 on a f450 chassie with a 97 5.9 and a 5speed # 10 plate slitly forward 3k govs afc housing forward afc spring kit star wheel adjusted forward kdp 14cm banks quick spool turine housing stock hx35 with banks big head set to 36lb boost and 5inch turbo back no muffler cold air intake valair 12.25 clutch with center upgrade red oak 5 hole 50hp injector
exoticsrnw is offline
post #2 of 2 (permalink) Old 03-16-2008, 06:23 AM
Yeah it will bolt up. You could even trade for a wastegated 12cm off a second gen. I've got one that I'd trade for that 18cm
Dual K20s is offline
