not starting after fuel pump tweak need help ASAP - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by XXXcumminsXXX, this thread has received 13 replies and been viewed 1595 times.
post #1 of 14 (permalink) Old 04-02-2008, 02:45 AM Thread Starter
so i took the cover off my fuel pump today just to see the membrane. well i put the cover back on and now my truck wont start! this is my daily and i need help fast!! please help someone
XXXcumminsXXX is offline
post #2 of 14 (permalink) Old 04-02-2008, 01:54 PM Thread Starter
let me make this a little clearer maybe....it was my fuel injection pump that the fuel screw is located on. i took the cap off to reveal that spring loaded membrane. when i put the cap back on it wouldnt start. ...could i have rotated it by accident which made it not start?
post #3 of 14 (permalink) Old 04-02-2008, 07:35 PM
Check to make sure both wires are hooked up to the fuel shut-off solenoid behind and just below the power screw on the backside of the injection pump.
imported_Smokem is offline
post #4 of 14 (permalink) Old 04-02-2008, 07:45 PM
T.D.G. Mafia Member #88
cumminspride's Avatar
I agree, fuel selinoid on the back of the IP. Must have 12V to start. Are you refering to the very top cap that has 3 allens and one flat, or 4 flats if it's non IC or manual? The spring loaded membrane you're reffering to is the diaphram, attached is the fuel pin and underneath is the starwheel. Tampering with these will not cause a NO Start.
cumminspride is offline
post #5 of 14 (permalink) Old 04-02-2008, 08:17 PM Thread Starter
anybody? please i need help! oh and by membrane i mean diaphragm to clear that up
post #6 of 14 (permalink) Old 04-02-2008, 08:21 PM Thread Starter
yea i accidentally took the diaphragm out and put it back in. how can i make it start again?
post #7 of 14 (permalink) Old 04-02-2008, 08:53 PM
Did you check the wires on the back side of the IP?
post #8 of 14 (permalink) Old 04-02-2008, 08:55 PM
There is no issue with removing the fuel pin and diaphram and reinstalling. The only thing that could cause a no start would be fuel supply. It has to have 12V dc at the terminals below the AFC air line that is attached to the cylinder head from the pump top that you removed.
post #9 of 14 (permalink) Old 04-02-2008, 09:18 PM Thread Starter
i'll check the wires...but i was stupid and didnt mark what position it was in...is there anyway to find the stock setting without using the mark?
post #10 of 14 (permalink) Old 04-02-2008, 09:19 PM
It doesn't matter.
