missing engine ID plate dont know cpl - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by slowkidpsd, this thread has received 2 replies and been viewed 811 times.
post #1 of 3 (permalink) Old 04-16-2008, 02:59 AM Thread Starter
Future Fummins!!
hi I picked up 2 6BT's and one of them does not have the engine ID plate so I don't have a CPL number. Is there another way to find out the cpl? Both motors came out of generators. one is p pumped and the one I can't identify is a rotary pump. I got a super rediculous deal on the pair :evil: so I am not to worried about not having the plate on there. I figure maybe someone on here might be able to point me in the right direction. :thanks:
Bryan
2004 F250 xlt 4x4 cc 6.0 torqshift arizona beige (metallic dirt), SCT, custom 4" turbo back straight pipe, quad pod w/ Isspro gauges, zoodad, egr cooler delete, B&W turnoverball, billet grill, flat black wheels, other misc.
1977 F250 4x4 High Boy soon to have 5.9 12 valve w/ a 10 or 13 spd and whatever it takes to make it possible :evil:
slowkidpsd is offline
post #2 of 3 (permalink) Old 04-16-2008, 12:29 PM
T.D.G. Mafia Member #88
cumminspride's Avatar
The rotary pump should have a 10mm plunger. No good for modifying. I don't think that p-pump has 12mm barrels either. You will want to look heavily into this. I am thinking niether have correct governors. Sorry for the lack of help on the cpl###.
cumminspride is offline
post #3 of 3 (permalink) Old 04-17-2008, 12:06 PM
Post a pic of the rotary pump. There are a couple of different types used in ag equipment.
Both will have load based governors. You need RPM based for road usage.
Philip is offline
