Head install questions - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bad_cummins, this thread has received 4 replies and been viewed 782 times.
post #1 of 5 (permalink) Old 04-23-2008, 02:28 AM Thread Starter
I pulled a head off for a guy I know about 4 days ago...this weekend I'm planning on going back together with it. The book I have tells me that head torque specs are 93 lbs with a torque sequence that ends up at 93...is this the specs? Also what are the valve lash specs? Also he wants me to remove and reseal the power steering pump...is there any special tooling to remove the pump, such as a gear puller or similar equipment?
01 Qc Cummins 4x4 long box, edge attitude with juice (HOT!!), 4" exhaust, afe stage 2 intake, HTB2 62/12, banks intake pleum, bully dog big fuel kit, stage three jammers, southbend 3250 DD, BD Blow off valve. PDR master and slave cylinder upgrade. Sold
2006 mega cab 4x4 auto. Stock for now.
bad_cummins is offline
post #2 of 5 (permalink) Old 04-23-2008, 04:36 AM
NHRDA Race Director
Twisted Shifter's Avatar
1st off you need to go buy new bolts .... head bolts are a single use item. You can use the stretch gauge if you want but I would never trust them.
This will be a good source of info for you ... Take the time to read and you will find most everything you need.
http://www.dodgeram.org/support_pgs/diesel_ix.htm
Twisted Shifter is offline
post #3 of 5 (permalink) Old 04-23-2008, 04:39 AM
TDG Mafia Member #56
Dieselwrencher's Avatar
I believe they are .010 Intake and .020 Exhaust. Do your head bolts have anything on the heads like +90? If so after your last torque sequence you have to tighten the bolt another 90* because these bolts are stretch to yield. There isn't any special tool to remove the power steering pump. If you have to replace the pump I believe there is a drive coupler that needs pressed off the old pump and pressed on the new pump on the first gens.
Putco light bar
Dieselwrencher is offline
post #4 of 5 (permalink) Old 04-23-2008, 04:41 AM
Oh, on another note like mentioned you can use the stretch gauge, if they are within specs they will be fine for a stock unit. I have seen these bolts take a lot especially if this thing is just a driver/ light hauler.
Putco light bar
post #5 of 5 (permalink) Old 04-24-2008, 01:26 AM Thread Starter
Well i appreciate the info guys. This however isnt my truck I'm just doing a head gasket on it. The head was sent off and checked it was slightly warped and is being machined and rebuilt. I heve not yet checked the block but will before i do the head gasket. On another note I already told the guy that we WILL be going back together with new head bolts, or I wasn't going to do it. I work for CAT so I've done this stuff before but I don't have any experience with Cummins execpt for my own truck...but I've never gone into the guts of it. Anyway keep it coming, past experiences mistakes you've made...I want all the info I can get.
Thanks agian guys
