bosch injectors - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by gon2sea, this thread has received 1 replies and been viewed 1625 times.
post #1 of 2 (permalink) Old 04-23-2008, 09:40 PM Thread Starter
bosch injectors
can someone help me identify some bosh injectors i have, they fit a 1992 engine.
on the body is stamped...Brasil kdal 59P5 791 10
and on the nozzle / tip is engraved 9351
they have four spray holes
bosch # 0 432 131 837
how are these compared to the stock injectors...
gon2sea is offline
post #2 of 2 (permalink) Old 04-23-2008, 09:59 PM
If they are a 4 hole injectors they are not stock for that 92 engine. The IC'd trucks used a 6 hole injector.
The nonIC'd trucks used a 4 hole injector. Measure the tip size on them. A nonIC'd used a 9MM tip. The IC'd engines used a 7MM tip.
Philip is offline
