alt. wiring - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by droolinforparts, this thread has received 2 replies and been viewed 957 times.
post #1 of 3 (permalink) Old 04-26-2008, 02:24 AM Thread Starter
droolinforparts's Avatar
Send a message via AIM to droolinforparts
alt. wiring
ok i have an old becyrice erie crane with a 6b (not turbo charged) i think the engine was built in the '80s and was wondering if anyone had a wiring diagram for the alternator. i forget if it has one big stud and three little ones as a plug or just three little ones...the plug and wires are obviously missing.
'03 F250 XL 6.0LK&N intake, mbrp 5" stacks, SCT X3 with tunes from innovative, 6" superlift, 315-75r-16,boost, pyro, fuel pressure, oil pressure gauges all in the a-pillar,h-11 studs, short throw shifter,fass 95/150 with complete custom fuel lines, south bend clutch, traction bars
Singles #118
B.O.M.B Squad #28
droolinforparts is offline
post #2 of 3 (permalink) Old 04-27-2008, 01:48 AM
Big stud is the power out, 2 of the little ones connect to the rotor brushes and may or may not have a ground on one, third may be the stator center or a ground.
Stator is low ohms, rotor is next range on the meter. If one end is grounded both will read to ground - zero ohms and rotor.
Big wire to battery and the rotor wires to the voltage regulator. For good service pay as close attention to the grounds as to the 12V wires.
keydl
81 Isuzu /C223na, 5spd
keydl is offline
post #3 of 3 (permalink) Old 04-27-2008, 05:48 PM Thread Starter
thanks alot...its working now
Singles #118
B.O.M.B Squad #28
