No Brake Lights!!!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by KYCummins, this thread has received 6 replies and been viewed 5779 times.
post #1 of 7 (permalink) Old 05-05-2008, 10:30 PM Thread Starter
No Brake Lights!!!!
i got a 90 dodge cummins that i jus completely swapped the whole body out on to eliminate the rust, at first when it was all back together i had no lights at all and figured out they were ground wires not hooked up, but no i got nothing in the back except taillights, no brake lights or turn signals, everything up front works, jus not the back, any suggestions please let me no
KYCummins is offline
post #2 of 7 (permalink) Old 02-01-2009, 09:53 AM
DIXIENORMOUS 4X4
Rebel Cummins's Avatar
dose your four way flasher work?
FSG Transport LLC
Owner-Operator Aug 2010 to present
West Alexandria, Ohio
I'm The Owner of FSG Transport and a driver.
Rebel Cummins is offline
post #3 of 7 (permalink) Old 02-11-2009, 02:46 PM
2nd Gen Guru
Mopar1973Man's Avatar
Fuses?
Brake light switch under the dash?
Thats a way to test the bulbs for function... But it might clue into multi-function switch problem...
Mopar1973Man is offline
post #4 of 7 (permalink) Old 11-03-2010, 05:38 PM
bigdognkat
brake light switch on steering column
The oem brake light switch on a dodge cannot be taken out of its bracket on the steering post as it breaks the contacts insidem I found out after two days of chasing out wiring! Napa auto sells one bettere than EOM and cheaper around $10 bucks be careful replacing it as once it clicks into square holder if you try to move it or remove it !! There goes another $10!!
bigdognkat is offline
post #5 of 7 (permalink) Old 11-09-2010, 06:43 PM
Possible you have a bad turn signal switch.
1990 Dodge 250 5.9 12V 727 auto Bone stock 256,000 miles when the odometer quit working a couple years ago. Needs paint bad, Az. sun baked it off. Afraid to re-paint it, fear it will get stolen and took to Mexico.
City Guy is offline
post #6 of 7 (permalink) Old 03-13-2011, 12:09 AM
Cummins
kickermatt's Avatar
it happens alot
Um those first gen trucks have always been known to lose electrical power. it happens a lot. and seening how the wiring in the truck consistes of about 3 wires. you just have to check grounds and shorts.
kickermatt is offline
post #7 of 7 (permalink) Old 03-21-2011, 12:39 AM
bmoeller's Avatar
Make sure you plugged into the correct harness. There are 2 under my dash with the same style plug. Only one of them handles the brake lights.
Haven't figured out what the other one is for yet. Tag on it says "switch", but not sure what switch........
"Obama = Hoax and Chains"
bmoeller is offline
