weird problem - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 02sprtcumns, this thread has received 6 replies and been viewed 1209 times.
post #1 of 7 (permalink) Old 01-22-2009, 04:35 PM Thread Starter
02sprtcumns's Avatar
weird problem
Im posting this for a friend.
He has a 92 250 and for some reason the truck isnt charging like it should. THe alternator tests 14.2v, but the amp gauge shows discharge. he can start the truck and it will start but coming to work lights go in and out and sometimes it wont start back when goes to leave work??? any ideas
02sprtcumns is offline
post #2 of 7 (permalink) Old 01-23-2009, 04:35 AM
There is a connection in the alt output wire. It is located about 1' foot away towards the passenger side fender well. Check it and see if it came loose or the terminals have corrided up and lost connection.
Philip is offline
post #3 of 7 (permalink) Old 01-23-2009, 02:02 PM
2nd Gen Guru
Mopar1973Man's Avatar
Do a voltage drop test on the alternator electrical going to the battery and the weak connection will show itself.
http://mopar.mopar1973man.com/tips/c...ed-circuit.htm
Mopar1973Man is offline
post #4 of 7 (permalink) Old 01-24-2009, 05:38 AM
DIXIENORMOUS 4X4
Rebel Cummins's Avatar
same problem with my truck, it was my crank shaft sensor on the front of the engine. but that dosen't mean it's the same problem. just give him a heads up
that could be a source of the problem.
FSG Transport LLC
Owner-Operator Aug 2010 to present
West Alexandria, Ohio
I'm The Owner of FSG Transport and a driver.
Rebel Cummins is offline
post #5 of 7 (permalink) Old 01-29-2009, 03:18 AM
had a problem with my 91 the other night all at once the amp gauge goes to discharge with all the lights and crap on .. then a half hour later it decides it wants to start charging again .. next day same thing ,, checked the alt and its ok ,and after some checkin i pulled the voltage regulator plug off and the terminals were corroded inside so it wasnt making good contact. pretty simple fix . if thats what the problem is .. doesnt hurt to check it anyway, the reg is on the firewall next to the wiper motor clean the terminals and use some dialectric grease when you put the plug in back together hope this was of some help.
saltman is offline
post #6 of 7 (permalink) Old 01-29-2009, 06:55 PM
BigRed Cummins's Avatar
Is his Tachometer working? if not it is the crankshaft sensor. Make sure the air gap is correct, and that the plug at the front of the engine, right by the #1 cylinder valve cover has a good connection. This is what tells the computer that the truck is running, and therefore tells the alternator to charge. or so I understand. I had the same problem, connector at the font of the engine was not making a good connection.
1992 W250-P-pump and some extra air, gone, but not forgotten.
2003 SVT Cobra
1984 Chevy K10
BigRed Cummins is offline
post #7 of 7 (permalink) Old 01-29-2009, 07:19 PM
2003 SVT Cobra
1984 Chevy K10
weird problem NEED HELP!!!!! wallyturcotte 5.9L Cummins 12 Valve (1994-1998.5) 7 04-23-2008 07:16 PM
WEIRD Problem....Need Help jennamax 2003-2007 6.0L Power Stroke 10 03-02-2008 08:00 PM
weird chip problem double-s-diesel 1994-2003 7.3L Power Stroke 7 01-19-2008 03:27 AM
Weird Gauge Problem worm drowner 1994-2003 7.3L Power Stroke 3 10-29-2007 08:34 PM
Weird problem with my truck Banshee365 2003-2007 6.0L Power Stroke 4 01-31-2007 05:02 AM
