Speed Question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dodgerules, this thread has received 14 replies and been viewed 1818 times.
post #1 of 15 (permalink) Old 01-28-2009, 04:37 AM Thread Starter
HI!
dodgerules's Avatar
Question Speed Question
How fast should a 727 and 3.00 gears go does any one have a setup like this because my truck is basically at the end of the rope at 60. thanks
1991 dodge d250 CTD pump tweaked, and stacks, yay!!!!
dodgerules is offline
post #2 of 15 (permalink) Old 01-28-2009, 04:40 AM
4play's Avatar
sounds about right, but you forgot to mention your tire size or height. and are you on the governor or what rpm. you sure about that ratio.
4play is offline
post #3 of 15 (permalink) Old 01-28-2009, 04:44 AM Thread Starter
HI!
dodgerules's Avatar
it has 265 75 r16. foot to the floor its about 70
post #4 of 15 (permalink) Old 01-28-2009, 05:00 AM Thread Starter
HI!
dodgerules's Avatar
under the hood on the hood there is a sticker with the options and it says its a 3.0 axle ratio.
post #5 of 15 (permalink) Old 01-28-2009, 05:28 AM
nonIC'd with a 727 had 3:07's.
I have 3:07's with a 518 OD trans. Stock 235 tires. I top out at 85 to 88 MPH in 3rd. Speedo doesn't go high enough to see what OD would top at.
check you throttle linkage adjustment. It is a noted problem with these trucks to not get full throttle linkage travel. Also check your TV cable. If it bottoms out it will stop the throttle from going full to.
Philip is offline
post #6 of 15 (permalink) Old 01-29-2009, 06:51 AM
M123KT-450's Avatar
3.07 gears and 32 inch tall tires. . . Truck should run 100mph all day long. . .you should be able to savely run 2,750Rpm all day long no stop. . .if not 3,250rpm. . .
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
1971 AMC /Jeep J4K-DRW.
1988 AMC /Jeep Comanche.
1991 Dodge RamCharger.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
M123KT-450 is offline
post #7 of 15 (permalink) Old 01-29-2009, 08:52 PM Thread Starter
HI!
dodgerules's Avatar
well what the heck is going on then?
post #8 of 15 (permalink) Old 01-30-2009, 08:17 AM
Like I said. Check the throttle linkage. It is a known problem on these trucks to be miss adjusted from the factory.
Philip is offline
post #9 of 15 (permalink) Old 01-30-2009, 10:18 PM Thread Starter
HI!
dodgerules's Avatar
it goes all the way and hits the high idle screw
post #10 of 15 (permalink) Old 01-31-2009, 01:52 PM
BigRed Cummins's Avatar
at what rpmm do you hit 70 mph? You could always check your rear gear ratio by pulling the rear cover, counting the ring gear teeth, and the pinion teeth, and then divide the number of ring gear teeth by the number of pinion teeth.
1992 W250-P-pump and some extra air, gone, but not forgotten.
2003 SVT Cobra
1984 Chevy K10
BigRed Cummins is offline
Question about 01 24v and 6 speed Purcell 24 Valve Performance 9 03-12-2009 02:05 AM
Maximum speed limit adjust question joeburnside Duramax 07.5-2010 (LMM) 0 04-28-2008 03:11 AM
quick top speed question badblackhemi 5.9L Cummins (2003-2007.5) 7 01-21-2008 03:26 AM
5 Speed Tranny Question.. Dad 5.9L Cummins (1998.5-2002) 4 07-02-2007 07:09 PM
6 speed question jdk 5.9L Cummins (2003-2007.5) 7 08-14-2006 02:18 AM
