Problems with crankcase venting - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BigRed Cummins, this thread has received 5 replies and been viewed 2767 times.
post #1 of 6 (permalink) Old 01-28-2009, 08:03 PM Thread Starter
BigRed Cummins's Avatar
Ok, Ive got a bunch of mods to my truck, and I am running around 48lbs of boost. I've no doubt got alot more demand on the stock crankcase vent than it was designed to handle. What are my options for a better vent system? Alot of the high dollar go fast drag cars run a vacuum pump on the crankcase to vent all of the blowby as well as dramatically decreasing windage from the rotating assembly and freeing up some ponies. I could no doubt find a way to make the stock vacuum pump do double duty, but it takes much more than that in order to seal the motor and make sure it doesn't suck the gaskets into the motor. What are my options?
1992 W250-P-pump and some extra air, gone, but not forgotten.
2003 SVT Cobra
1984 Chevy K10
BigRed Cummins is offline
post #2 of 6 (permalink) Old 01-29-2009, 02:21 AM
Here is an option: http://www.dieseltruckresource.com/d...d.php?t=199914
91 W250, rusty POS, no afc, PODS, AM FP gauge, Isspro boost + pyro, 91.5 W350
921stgen is offline
post #3 of 6 (permalink) Old 02-02-2009, 01:38 AM
saw your problem and just had to reply to it "" might sound a little far fetched but i dont see why it wouldnt work ,, ive been running a circle track car for years and i use a panovac system on it ,, very inexpensive and works extremely well ,, youd have to chop a couple extra holes in your valve cover to install the grommets and weld the fittings in the exauhst down pipe but evacuating the excess crankcase pressure is what your trying to acomplish isnt it with all the other mods youve done on your truck this one is simplicity ,, speedway motors catalog,, good luck"..
saltman is offline
post #4 of 6 (permalink) Old 02-02-2009, 03:48 AM Thread Starter
I thought that those systems relied on the vacuum generated by the exhaust exiting the headers to pull the crankcase gases out. I dont know if I have low enough back pressure to run that. Is your circle track car open header, or does it have an exhaust with race mufflers?
2003 SVT Cobra
1984 Chevy K10
post #5 of 6 (permalink) Old 02-05-2009, 03:53 AM
yes it has headers with a muffler if you would want to call it that ,, the system really relys on the exauhst passing by the tubes welded in the collectors they act like a venturie and the parts that are in the grommets on the valve covers are no more than just a plain ole pcv valve so the more exauhst that is passing the tubes in the collector the more it sucks so ta speak,, the tubes that are welded in do however need to be installed correctlyand if i remember right they go in at a 45 degree angle you can use a two doller angle finder for that..
saltman is offline
post #6 of 6 (permalink) Old 02-11-2009, 02:44 PM
2nd Gen Guru
Mopar1973Man's Avatar
I've seen something like this on the 2nd gen truck for a crankcase vent. Using a exhaust one-way valve and positioning it back by the down pipe they managed to create a slight vacuum to suck the oil vapor out of the crankcase... But on the 2nd gens there is a problem with oil spillage through the stock vent..
Mopar1973Man is offline
crankcase breather Okie2500 5.9L Cummins (1998.5-2002) 3 01-24-2008 04:17 PM
OBS Crankcase Ventilation blackpsd 1994-2003 7.3L Power Stroke 1 01-28-2007 03:05 PM
Crank case venting NMU98 Euro-Diesels 0 08-18-2005 12:40 PM
