Oil pan gasket - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Rob, this thread has received 5 replies and been viewed 1578 times.
post #1 of 6 (permalink) Old 02-04-2009, 04:48 PM Thread Starter
Rob
Oil pan gasket
I have a leak at the oil pan and need to replace the gasket (1990 RAM 4x4), I was told I have to pull the motor to do this??? Is that true, must be an easier way, maybe pull the driveshafts, remove trans crossmember, motor mounts and pull up on it a bit? Anybody do this before?
Rob is offline
post #2 of 6 (permalink) Old 02-04-2009, 08:02 PM
Formerly CursedtoFirst45
StrokeThis's Avatar
you'll need to jack up the rear of the engine(place jack over transmission mount), loosen the motor mounts, and simultaneously jack up the front a little bit. I just had mine out, its a daunting task. But it can be done without removing the engine.
Eric
1994 Dodge Ram 2500
You can take our information, you can try to shut us down, but we're still here, and we're going to be better than ever!!
-John DeereGreen
StrokeThis is offline
post #3 of 6 (permalink) Old 02-04-2009, 08:22 PM Thread Starter
Rob
Thanks for the tips on that, the thought of pulling the engine is hardly appealing. I'll wait for warmer weather before diving into it
Rob is offline
post #4 of 6 (permalink) Old 02-22-2009, 10:33 PM
I was wondering...could a person remove the front bolt from the springs and lower the front differential enough to drop the pan? Maybe even unbolt the shocks at the diff. What do you guys think?
93 W250 Club cab 250000 mi orig. owner
02 2500 4X4 QC auto
TMWeber is offline
post #5 of 6 (permalink) Old 02-24-2009, 05:17 AM
TM it would work doing it that way.Tthe problem might be getting the bolts out of the spring eyes. They might be rusted in solid.
Philip is offline
post #6 of 6 (permalink) Old 03-01-2009, 07:14 PM
Thanks Phillip. I got this idea when I was replacing the drag link and had trouble on the pitman arm side. I removed the bolt and lowered the differential. In my case it came out very easy. This got me thinking of using this method to remove the oil pan versus lifting the engine. Seems much easier.
02 2500 4X4 QC auto
TMWeber is offline
Pan gasket Caos56 1994-2003 7.3L Power Stroke 1 01-30-2009 03:09 AM
Oil Pan Gasket Diesel dude 7.3L and 6.9 IDI (Pre 1994) 1 01-20-2008 08:23 PM
gasket questions cookiemonsterblue 5.9L Cummins 12 Valve (1994-1998.5) 6 05-02-2007 03:28 AM
Head Gasket time should I stud it and A/M Gasket it? cdooguy 2003-2007 6.0L Power Stroke 7 04-26-2007 04:36 AM
Gasket time... BogginF350 2003-2007 6.0L Power Stroke 1 10-17-2005 03:45 AM
