tranny swap? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by t-rav, this thread has received 3 replies and been viewed 1185 times.
post #1 of 4 (permalink) Old 02-18-2009, 05:24 PM Thread Starter
tranny swap?
Is it possible to swap 6spd trans into 93 w250?It already has getrag 5spd.
t-rav is offline
post #2 of 4 (permalink) Old 02-19-2009, 05:35 PM
Ghost
Phily's Avatar
I would think so. I believe the 5 speeds out of those got swapped out for NV4500's and NV4500's got swapped out for 6spds in the 2nd gens plenty of times that they even made a kit for it.
Phily is offline
The Following User Says Thank You to Phily For this addition to TDG:
t-rav (02-20-2009)
post #3 of 4 (permalink) Old 02-19-2009, 07:31 PM
Tebow-in'...
mudguppy's Avatar
dunno, but i'm thinking that worst case you'd have to pick up a different engine-to-transmission adapter plate (????).
Travis
2011 F350 SRW CC/SB 4x4 Lariat 6.7 PSD Dark Pearl Metalic
1974 Bob'd Deuce on 16.00-20 XZLs, locked front and rear, hydro steering, front and rear winches, 5.9CTD/nv4500, hydro-boosted disc brakes
Member since Jul 05, Dually Club Member #63, American Club Member #42, FOSP Member #8
mudguppy is offline
post #4 of 4 (permalink) Old 02-28-2009, 04:13 PM
You need the engine adapter.
You will need a 2nd gen starter. The frame will eather have to be notched or heated and bent up a small amount to clear the 2nd gen starter.
If it is an early model NV5600 with the small input shaft you can reuse the getrag clutch. If its the larger shaft then a different flywheel and clutch. The 1st gen hydr's can be reused with a little fab work.
You will need to MFG the mounting brackets for the transfer case shifter.
Its not to bad of swap. I know a guy that has done it. I'll have to ask on driveshafts.
Philip is offline
Tranny Swap. danktank6.9 7.3L and 6.9 IDI (Pre 1994) 0 04-12-2008 01:05 AM
tranny swap KWT800 Medium and Heavy Duty 15 01-20-2008 10:58 PM
tranny swap gotsmoke00 1994-2003 7.3L Chips & Tuners Forum 3 04-04-2007 05:00 PM
Tranny Swap??? bigdraft General Dodge Discussion 1 05-21-2006 09:52 PM
tranny swap TrbdBigGrn 5.9L Cummins 12 Valve (1994-1998.5) 5 11-08-2005 04:56 PM
