intake - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by thenewguy, this thread has received 2 replies and been viewed 804 times.
post #1 of 3 (permalink) Old 02-25-2009, 05:17 PM Thread Starter
intake
im a first time cummins owner and i have a 90 w250 and looking for a good intake anyone have any websites or suggestions?
thenewguy is offline
post #2 of 3 (permalink) Old 02-27-2009, 04:54 AM
If your talking about a preturbo open air intake and filter. You might have a problem. That 90 has a small inlet H1C on it. If I remember right it is a 3" opening. All the intercooled 1st gens has a 4" turbo inlet. All the aftermarket setups are made for the IC'd trucks.
So your looking at mfg'ing your own setup.
Philip is offline
post #3 of 3 (permalink) Old 03-12-2009, 04:14 AM
Hey man check this Thread out, (https://www.thedieselgarage.com/forum...t=BHAF+part)if you are going to do your own intake instead of fitting an aftermarket one there are some part numbers for a BHAF, you can get at carquest, napa, etc. Good luck! its easy and pretty cheap
1991 cummins ctd reg cab
2011 VW Jetta 2.0
ramthisny is offline
Which Air Intake? RVHAULER 1994-2003 7.3L Power Stroke 12 01-24-2008 06:33 PM
Intake 97cummins 12 Valve Performance 5 12-28-2007 12:22 AM
Air Intake comanchejoe 7.3L and 6.9 IDI (Pre 1994) 7 11-27-2007 12:45 AM
AFE Intake drummerboydw 5.9L Cummins (1998.5-2002) 7 10-27-2006 07:46 PM
New AFE intake fix chargedfe 2003-2007 6.0L Power Stroke 9 08-25-2006 01:44 PM
