Finished The Motor Swap! (Pics) - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BigRed Cummins, this thread has received 10 replies and been viewed 2047 times.
post #1 of 11 (permalink) Old 03-18-2009, 03:43 AM Thread Starter
BigRed Cummins's Avatar
Finally got finished with the P-pump motor swap after my KDP got me. Its a 1997 215 horsepower motor from a Ram 3500 Dually 5spd. It has 80,000 miles and came complete, turbo to oilpan, for $2150. It actually swapped in really easy, with only a few hiccups here and there. I have already ground my own #100 fuel plate, as well as all of the other free mods. I used the H1e/16 hybrid off of my old motor, as its a bigger turbo than the HX35 that came with the new engine. For those of you wanting to do the P-pump swap, DO IT! You will not regret it. IT has a ton more power than my old motor and is much more responsive. The only issue I have is that the throttle is very touchy. If you have any questions about the swap, shoot me a PM.
1992 W250-P-pump and some extra air, gone, but not forgotten.
2003 SVT Cobra
1984 Chevy K10
BigRed Cummins is offline
post #2 of 11 (permalink) Old 03-21-2009, 02:21 AM
TDG Mafia Member #56
Dieselwrencher's Avatar
Glad to hear you got it running again! But your pics don't show up..........
Putco light bar
Dieselwrencher is offline
post #3 of 11 (permalink) Old 03-21-2009, 04:21 AM Thread Starter
Ok, here they are, sorry for the glitch...
2003 SVT Cobra
1984 Chevy K10
post #4 of 11 (permalink) Old 03-22-2009, 02:18 AM
covey88's Avatar
looks great! love that body style too!
96 DODGE RAM 2500 ext. cab 4x4 auto trans. the only thing that is done is a BHAF, I removed the cat. and muffler(straight piped 3"), 16.5*timing and moved afc housing forward and a custom ground 100 plate too! flipped the washer on the diaphragm in the afc, 4k gov springs, 60lbs valve springs
covey88 is offline
post #5 of 11 (permalink) Old 03-22-2009, 06:59 PM
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
Awesome pickup! :
Logan
Do Or Die Garage Experiment
cummins power is offline
post #6 of 11 (permalink) Old 03-25-2009, 04:58 AM
Very nice!
Putco light bar
post #7 of 11 (permalink) Old 03-26-2009, 06:53 PM
hehe, that thing got some go fast?
how you been charlie
cumminsranger07 is offline
post #8 of 11 (permalink) Old 03-28-2009, 06:56 PM
Carolina Boy
Das Bar 2k4's Avatar
nice ride
Greg aka Cumminsproud
Go Clemson Tigers Football
96 Ram 3500 Slt Ext Cab 12v cummins nv4500 afc housing and plate full forward with 4in exhaust and k&n drop in and smoke screw turned in a few turns it wants to be a 2.6 truck
94 Ram 2500 Slt Reg Cab 12v cummins auto: custom grind fuel plate, afc housing ff, afe stage 2 bhaf, mbrp 4in str8 pipe exhaust, 3k gsk, isspro gauges trans, egt, and boost, 20in Moto Metal punishers on 33's -let the smoke start rollin
new truck 96 p pump 24v
floor it diesel performance and raw diesel performance all the way
Bracken Pullin Team 2008-2010 MSTPA Points Champions
SINGLES CLUB # 210 former
DUALLY CLUB # 92 Wide Body Status
Das Bar 2k4 is offline
post #9 of 11 (permalink) Old 03-30-2009, 01:03 AM
Mafia #42
HighTQCummins's Avatar
Location: Valley Forge PA/West Long Branch NJ (college)
Send a message via AIM to HighTQCummins
lookin good man. I like the lights up front
Hank
TDG and the Mafia lives on
TDG B.O.M.B. Squad #5
My Truck:2007 Toyota Tacoma V6 4x4
Diesel is in my blood, I guess you can call it a disease, sadly there is no cure for it, it's my cross I must carry
HighTQCummins is offline
post #10 of 11 (permalink) Old 03-30-2009, 06:04 AM
CENTRAL IOWA #1
polarischevy05's Avatar
looks great
97 3500 dually 4x4 #5 tst plate, 5 inch stacks, lock up switch, auto meter gauges, silencer ring mia, intake, train horn
01 2500 4x4 Juice w/attitude, hot code, 6 inch stacks, super B turbo, intake, black holley lift pump, lock up switch, stage 5 jammer injectors, BD anti defueler, goerend trans, snow performance stage 3 water meth
Best 1/4 mile time 13.01 @ 104
Next Mods-Nitrous 200hp?????, Head studs, Bigger turbo
polarischevy05 is offline
New CB mount finished w/ Pics Stroked383 General Ford Truck and Excursion 11 02-28-2008 10:44 PM
some finished product pics.... 2008fx4 2008-2010 6.4L Power Stroke 17 10-22-2007 01:51 AM
C-500 finished!!!! pics.... redcatman Medium and Heavy Duty 19 09-12-2007 11:55 PM
Finished 75 Dodge D200 Club Cab Cummins swap project rcts 5.9L Cummins (Pre 1994) 1 12-12-2006 08:29 PM
lift finished this weekend (pics) jamesL 5.9L Cummins (2003-2007.5) 32 03-11-2006 03:04 AM
