Ole JIm Problem - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Ole JIM, this thread has received 6 replies and been viewed 1171 times.
post #1 of 7 (permalink) Old 03-21-2009, 03:40 AM Thread Starter
Ole JIm Problem
my Dodge diesel ran yesterday --but--I had to bleed several injectors today to get it running I checked the fuel lines from the fuel tank--all seem OK! no cracks no fraying I dono? about my fuel delivery pump? as I dono? how to check it? here locally--pump runs aprox-$75 to $100--any Suggestions? Ole JIM--
Ole JIM is offline
post #2 of 7 (permalink) Old 03-22-2009, 07:01 PM
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
Check the fuel pressure to the injection pump is my .02
Logan
Do Or Die Garage Experiment
cummins power is offline
post #3 of 7 (permalink) Old 03-22-2009, 09:21 PM Thread Starter
--OK how? do I do that?
Ole JIM is offline
post #4 of 7 (permalink) Old 03-26-2009, 11:55 AM
Hot Rod Farm Boy
I turned 21
T into the line that feeds your pump, then hook up a fuel pressure gauge to the open port.
Logan
post #5 of 7 (permalink) Old 04-04-2009, 11:18 PM
Cummins Junkie
cumminsman315's Avatar
check your fuel filter too, cause we had one that leaked and it would get air into the fuel lines, if it sat over 15 minutes
Bros rig 06 Quad Cab NV4500 3500 Single CP3 Single Turbo-8/14/[email protected] http://www.youtube.com/watch?v=lVRrjK4YeCw
cumminsman315 is offline
post #6 of 7 (permalink) Old 04-13-2009, 06:20 AM
There is a prime lever on the side of the lift pump - give it 20 flips or so. The IP needs a couple of #s pressure to start the first lick. If the pressure is bleeding off the prime will repressurise the pump, if the lines are sucking air it will often put the air back in the tank and it gives you time to look for leaks from the lift pump lines
keydl
81 Isuzu /C223na, 5spd
keydl is offline
post #7 of 7 (permalink) Old 04-29-2009, 03:48 AM Thread Starter
Thanks Guys problem FIXED--Ole JIM--
Ole JIM is offline
4X4 problem henk 5.9L Cummins 12 Valve (1994-1998.5) 7 01-07-2008 03:06 AM
Is this an ICP problem? imported_LiftedBlackHD 2003-2007 6.0L Power Stroke 18 06-26-2007 01:41 PM
1 new problem, 1 old problem, 1 problem fixed LOL Liftedpsd 2003-2007 6.0L Power Stroke 16 04-23-2007 12:13 PM
Fuel Pressure Problem? Lift problem? Going on long trip this weekend! JaredMTFD 5.9L Cummins (1998.5-2002) 4 01-24-2007 03:35 PM
Help with problem WOJO 1 1994-2003 7.3L Power Stroke 16 03-22-2006 07:45 PM
