Injector Questions - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Dual K20s, this thread has received 6 replies and been viewed 1340 times.
post #1 of 7 (permalink) Old 04-27-2009, 04:53 AM Thread Starter
Injector Questions
I'm looking for the specs for 1st gen injectors. Did they change injector design when they became intercooled?
Whats the stock pop-off pressure?
Spray angle?
Number of holes and orifice size?
Thanks
Dual K20s is offline
post #2 of 7 (permalink) Old 04-29-2009, 04:23 PM
The spray angles are the same between IC'd and nonIC'd VE equipted engines.
I am thinking 245 bar on pop pressure.
IC injectors are a 6X.009" hole size. I can't remember the nonIC size. 4X.012's seem to come to mind.
IC injectors are a 7MM body. The nonIC has a 9MM body size.
Philip is offline
post #3 of 7 (permalink) Old 05-01-2009, 06:53 AM
Of Course
Non intercooled injectors are 4x0.012" with a 9mm shank, intercooled injectors are 6x0.009" with a 7mm shank. Why would the spray patterns be the same when the piston designs are different?
That Guy is offline
post #4 of 7 (permalink) Old 05-03-2009, 03:40 AM
That guy you are right. The spray angle is different on a nonIc engine. I couldn't find the exact angle listed anywhere. I did call a friend that has some custom EDM's done for a nonIC engine. He was told it had a 135 degree spray angle. Our IC engines is a 145 degree.
Philip is offline
post #5 of 7 (permalink) Old 05-03-2009, 06:33 PM
Of Course
Actually the Non IC engines have a piston bowl in the 152-155 range.
That Guy is offline
post #6 of 7 (permalink) Old 05-04-2009, 12:45 AM
HHHHmmmm thats p-pump spray angle range.
Philip is offline
post #7 of 7 (permalink) Old 05-04-2009, 03:47 AM
Of Course
The '91-93 intercooled pistons are the same as the '96-98 pistons, 145 angle.
That Guy is offline
injector questions jojo00 7.3L and 6.9 IDI (Pre 1994) 3 09-18-2007 02:49 AM
more injector questions! barry1me 2003-2007 6.0L Power Stroke 12 08-20-2007 07:30 PM
Injector questions Macktruckdriver 1994-2003 7.3L Power Stroke 28 07-28-2007 08:10 PM
Injector questions.. blackcloudCTD95 5.9L Cummins 12 Valve (1994-1998.5) 42 07-17-2007 05:10 PM
Injector questions TimMTP 5.9L Cummins (2003-2007.5) 7 04-13-2006 08:06 AM
