Rear End Ratio? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Ole JIM, this thread has received 7 replies and been viewed 2447 times.
post #1 of 8 (permalink) Old 05-01-2009, 01:02 AM Thread Starter
Rear End Ratio?
where? do I Look to find my Rear End ratio on my 90 Dodge-THANKS --OLe JIM--
Ole JIM is offline
post #2 of 8 (permalink) Old 05-01-2009, 01:30 AM
cowboytw13's Avatar
Use the Calculate Rear End Gear Ratio. you need to know your tire diameter, speed, and RPM's and that'll tell you what gears you have
https://thedieselgarage.com/projects/...c/tirecalc.htm
cowboytw13 is offline
post #3 of 8 (permalink) Old 05-01-2009, 04:41 AM Thread Starter
Gear Ratio?
I*M told theres a tag? or Ratio stamped?--or Raised letters? some where? --on the rear Pumpkin--what I need to know! is Where?--THANKS!--Ole JIM--
Ole JIM is offline
post #4 of 8 (permalink) Old 05-01-2009, 04:59 AM
If it hasn't been removed. The ratio tag would be mounted at the 11:00 position when looking at the cover.
There might be a decal under the hood with the factory options listed on it.
If you have a stick shift truck the factory had 3:54's and 4:11's as ratio's. If it is an auto truck then it should be 3:08's.
Philip is offline
post #5 of 8 (permalink) Old 05-28-2009, 04:21 AM
JDolezal's Avatar
If you can't find any tags or a build sticker take off your diff cover, count the teeth on your Ring gear and divide by the number of teeth on your Pinion gear.
JDolezal is offline
post #6 of 8 (permalink) Old 05-31-2009, 02:23 PM
It is stamped on the ring gear. It will look like this XX-XX no need to waste time counting gear teeth if you have the cover off. A 4:10 gear would be stamped 10-41.
Philip is offline
post #7 of 8 (permalink) Old 07-06-2009, 09:25 PM
Some of the 5spd trucks did get a 3.07 gear too..its really rare.. I swapped a set in my '92 and just got a factory 5spd 3.07 '93 this past winter..the factory under hood sticker even has the specs ..its nice ...
Thanks
Deo
2000 Excursion XLT 4x4, 12V P Pump Cummins, 0-ringed head, AE G56 6 spd, southbend FE clutch, guages, lazer dv, 370's, Black Vinyl floor, 285 Nitto Dura Grapplers, 4" remote BD Exhaust Brake, 4" exhaust, Working on Twin turbos HX50 9cm &BHT3E 20cm with tial external wastegate, http://www.turbodieselregister.com/f...sion-redo.html
1992 dodge w350 cummins, SRW, 5spd Getrag, 3.07 gears, guages, custom 8' dumping flat bed
1996 VW Passat TDI Wagon, guages, Chip, Big injectors Rebuilt KKK24 Turbo, 2.5 " stainless techtonics exhaust, 5 bolt GLX brakes, bilsteins HD suspension, Shine rear swaybar, frost heater, heated black leather interior.
therabbittree is offline
post #8 of 8 (permalink) Old 07-08-2009, 06:57 AM
DIXIENORMOUS 4X4
Rebel Cummins's Avatar
Well my old 1992 Cummins D-250 had 3:55s factory and it had the 518 auto.
FSG Transport LLC
Owner-Operator Aug 2010 to present
West Alexandria, Ohio
I'm The Owner of FSG Transport and a driver.
Rebel Cummins is offline
A/R Ratio cummins power 5.9L Cummins 12 Valve (1994-1998.5) 6 04-06-2009 12:01 PM
how do I tell the rear end ratio ifurlong Medium and Heavy Duty 5 02-07-2009 08:53 AM
rear end ratio imported_newtodiesel 2003-2007 6.0L Power Stroke 3 02-27-2008 12:43 PM
changeing rear end gear ratio pontiacross GM Performance Forum 6 07-11-2007 04:51 AM
Gear ratio Chunk 2003-2007 6.0L Power Stroke 12 09-29-2005 02:36 AM
