92 auto transmission - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by HP Freak, this thread has received 7 replies and been viewed 1858 times.
post #1 of 8 (permalink) Old 05-16-2009, 01:02 AM Thread Starter
OK is the auto trans in a 92 dodge electronically controlled? Also what transmission is it? and how many HP will it with stand in stock form?
Thanks HP Freak
HP Freak is offline
post #2 of 8 (permalink) Old 05-18-2009, 03:20 AM
The trans is a 46RH also called a 518. The only electronic's is the OD solenoid. It is controlled by the PCM mounted behind the battery.
The trans can handle around 300 HP or so easy. The stock converter can't hold that much. It was made loose by Dodge. The best improvement you can do is to replace it before doing much to engine HP.
Philip is offline
post #3 of 8 (permalink) Old 06-08-2009, 02:34 PM Thread Starter
Ok so finally got it going and got it home...(the battery cables where bad) but OD does not work, so can somebody tell me how to wire in the switch? this truck is a worn out pile and there is wires hanging everywhere so it is a little confusing. I'm not planing on fixing it up but i need it so i have a rig to drive as my chevy just got totaled.
Thanks HP Freak
HP Freak is offline
post #4 of 8 (permalink) Old 06-08-2009, 03:41 PM
Is the charging system working?
There is a switch in the front trans cooler line.It is located by the front of the trans pan, driver side. If the wires are off it the OD will not work.
Philip is offline
post #5 of 8 (permalink) Old 06-09-2009, 01:31 AM Thread Starter
No the alt. is bad. does that make difference? I checked the switch on the trans cooler line and it is plugged in. Anything else?
HP Freak is offline
post #6 of 8 (permalink) Old 06-09-2009, 04:51 AM
Don't bet on the alt being bad. If the PCM doesn't see a RPM reading from the crank position sensor it will not turn on the alt/ A/C, OD, CC.
Check the air gap on the CPS. It should be around .050". It is mounted at the 11:00 position on the harmonic balencer. When looking at the front of the engine.
Philip is offline
The Following User Says Thank You to Philip For this addition to TDG:
HP Freak (07-22-2009)
post #7 of 8 (permalink) Old 07-22-2009, 02:30 AM Thread Starter
Ok so i got it working right... Thanks guys!!!!!!!!! But now i'm playing with the IP and was wondering how far i can push things before it starts breaking things, it is totally stock . Is all i have is a boost gauge so how much boost can i build with how much smoke before things start to give.
HP Freak is offline
post #8 of 8 (permalink) Old 07-23-2009, 02:54 AM
When you start turning up he fuel there are 2 more gauges
Pyrometer - it will last a long time below 1200 deg, hotter is less life. A kit is a little over $100 and repaired seems to start around $650
Trans temp - start thinking of parts when it hits 250 deg and thinking of changing the trans fluid a little early, over 300 F put it on the 'to do list'.
The converter will probably break if you turn it up and beat on it, might order one to have when it does. If you want HD parts get them also, the seals and standard auto trans parts are everywhere.
keydl
81 Isuzu /C223na, 5spd
keydl is offline
Chevette auto transmission 4rcFed Whats Been Sold 7 02-10-2009 03:11 PM
auto transmission ratio ? bobh Medium and Heavy Duty 9 01-30-2008 01:25 AM
94 auto transmission question NukleusX 5.9L Cummins 12 Valve (1994-1998.5) 0 12-12-2007 09:59 PM
TRANSMISSION FILTER ON 250 2wd AUTO AND OTHER QUESTION imported_QUICK83 2008-2010 6.4L Power Stroke 1 02-25-2007 02:31 AM
DT 466 Transmission circle5 Medium and Heavy Duty 14 02-02-2007 01:13 AM
