93? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Stroker81, this thread has received 5 replies and been viewed 996 times.
post #1 of 6 (permalink) Old 06-07-2009, 08:05 PM Thread Starter
93?
what size turbo are on the 93 cummins? My buddy was wanting to know he said he thought it was a hx28. I thought hx 35. Let me know if you guys no.
Stroker81 is offline
post #2 of 6 (permalink) Old 06-08-2009, 03:39 PM
A 93 will have a H1C on it stock. The HX35's didn't come out till the 95 models.
Philip is offline
post #3 of 6 (permalink) Old 06-09-2009, 03:17 PM
2nd Gen Guru
Mopar1973Man's Avatar
Phillip's right...
Mopar1973Man is offline
post #4 of 6 (permalink) Old 06-11-2009, 07:21 PM Thread Starter
What would the advantage be if he swapped turbos? He had one laying around and didnt no if it was worth the effort to swap.
post #5 of 6 (permalink) Old 06-12-2009, 04:40 AM
Going from a H1C to a HX35 isn't much of an upgrade. If he plans on throwing much fuel at the engine. He will run out of turbo fast.
That H1C should have a 54MM impeller. A HX35 is normaly a 56MM impeller.
Philip is offline
post #6 of 6 (permalink) Old 06-16-2009, 01:34 PM
2nd Gen Guru
Don't get me wrong... But a HX35 with work on your truck but like Phillip is saying it will run out rather quickly. I've got a buddy with a 92 with a HX35 and can bury a 30 PSI boost gauge like nothing... Stock injectors but the pump is turned up.
