Gear Fluids - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BlowinSmoke, this thread has received 4 replies and been viewed 1245 times.
post #1 of 5 (permalink) Old 06-25-2009, 12:18 AM Thread Starter
BlowinSmoke's Avatar
Gear Fluids
What would be a better recommended gear fuild in the Getrag 360 trans and Transfer case on these first gen. trucks? Does it make a difference being a 1ton truck? Thanks.
BlowinSmoke is offline
post #2 of 5 (permalink) Old 06-28-2009, 07:17 PM
which transfer case do you have? the trans takes motor oil. amsoil recommends 5-30 oil in the trans
01quadcab is offline
post #3 of 5 (permalink) Old 06-30-2009, 06:39 AM
Synthetic motor oil, overfill by a quart because the lube path for a bearing is not positive.
keydl
81 Isuzu /C223na, 5spd
keydl is offline
post #4 of 5 (permalink) Old 06-30-2009, 02:05 PM
CrowsSynthetics's Avatar
Send a message via Yahoo to CrowsSynthetics
Post
I think if you go here it will take you here may be the info is there for you. If you cant find any info I can make a few calls for you.
Bill
2003 F250 FX4 SUPERCAB SPORT XLT 7.3 PSD
Amsoil 3000 5w 30 ,Amsoil EaAU Air Filter ,Amsoil Pre filter-EaPF13,
Amsoil Dual Remote By-pass BMK-16A, Amsoil ATF & Transfer case, Amsoil 75w-140 fluid front & rear end, Amsoil Antifreeze Fluid
Edge with Attitude, 4" Turbo Back Exhaust,
5" SS Tip
, Transmission Magnefine filter, Sportman Tonneau Cover & Bush Fender Flairs
Now in the stable a new Black 2009 Jetta Sedan TDI
CrowsSynthetics is offline
post #5 of 5 (permalink) Old 07-01-2009, 01:09 AM
BigRed Cummins's Avatar
According to Alldata, the trans takes 5w30 motor oil. I filled mine a quart over with 5w30 synthetic Mobil One, and Haven't had a single problem. Also according to Alldata, the transfer case takes: "Transfer Case Fluid Multipurpose Gear Oil (A.P.I. specification GL-5 or engine oils labeled A.P.I. Service SF/CC or SF/CD)." I put regular old 75w90 gear oil in mine and it has worked fine.
1992 W250-P-pump and some extra air, gone, but not forgotten.
2003 SVT Cobra
1984 Chevy K10
BigRed Cummins is offline
The Following User Says Thank You to BigRed Cummins For this addition to TDG:
CrowsSynthetics (07-01-2009)
changing tranny fluids imported_7.3FordPower 1994-2003 7.3L Power Stroke 1 01-17-2008 04:23 PM
Synthetic fluids catdude 5.9L Cummins (2003-2007.5) 2 11-23-2007 12:59 AM
Synthetic Fluids BillsFan 1994-2003 7.3L Power Stroke 1 10-30-2007 11:30 AM
What type of Fluids 91rangerturbo General Dodge Discussion 0 06-06-2007 02:40 PM
tans fluids moose99psd 1994-2003 7.3L Power Stroke 8 07-30-2006 08:21 PM
