CB Radio Interferance? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BigRed Cummins, this thread has received 11 replies and been viewed 3316 times.
post #1 of 12 (permalink) Old 06-29-2009, 06:33 PM Thread Starter
BigRed Cummins's Avatar
Ok, I've got a CB radio in my truck that gets a ton of interferance. I cant quite tell where it is coming from, however I know it is coming through the antenna. I have switched several antennas, coax, and even changed the mounting of the antenna. The reason I know it is radio interferance through the antenna is if the antenna is unplugged, the noise goes away. The noise only occurs when the ignition switch is in the "run" position, not the "acc" position. I think it might be the computer making all that racket, but I am not sure. It isnt alternator noise, and obviously not ignition system noise. have any of you ever run into this problem before? It's driving me nuts.
1992 W250-P-pump and some extra air, gone, but not forgotten.
2003 SVT Cobra
1984 Chevy K10
BigRed Cummins is offline
post #2 of 12 (permalink) Old 06-30-2009, 06:36 AM
I think that you have found it.
Possible helps
a good or excellent ground at the radio and the antenna
a twisted pair power wire to the battery, greater than 2 turns per foot
do a full ground for radio frquency to the hood, fenders, fender liners and cab
Last thing to try - metal shield to the computer wiring, without a field strength meter covering the nodes. An Opto Scout is around $400 and will survey for freq and signal streingth
The SWR on the ant is also on the list
keydl
81 Isuzu /C223na, 5spd
keydl is offline
BigRed Cummins (07-02-2009)
post #3 of 12 (permalink) Old 07-12-2009, 04:02 AM
bmoeller's Avatar
May need to fiddle with the RF Gain and Squelch switches as well. Some areas around here are worse than others for background interference. I live in a high traffic area where 5 interstate highways converge. Get out in the sticks and a lot of it goes away.
High tension power lines or being near some electrical sub-stations, it can be pretty bad. Import radios with really good "ears" can pick a LOT of that noise.
Another possibility, is that you may need a noise filter on the power supply, if you don't get power directly from the battery. What you may picking up is from something in the engine compartment, like the alternator. I have to run a filter on 2 trucks. They pick up the noise from the injectors.
"Obama = Hoax and Chains"
bmoeller is offline
post #4 of 12 (permalink) Old 07-13-2009, 03:53 AM
Dropping noise from an environment that supplies digital without a shield can most times be cured without filters by using the marine practice of twisting the ground and power wires more than 2 turns per foot. If you have a specific frequency computing the length of twist can use the standing wave to remove interference.
Cat 5 cable can be used - it is pre twisted by the pairs - one of each pair for ground and the other for power.
keydl
keydl is offline
post #5 of 12 (permalink) Old 07-13-2009, 02:29 PM Thread Starter
Nope, its not environmental interferance, and not the alternator, because it does it when the motor is not running, and it doesnt change with RPM. My power wires go directly to the battery. I will try twisting them to see where I get with that. SWR is 1.1 on Channel 1, and 1.2 on Channel 40. Hood, fenders, bed, doors, tailgate, and even the exhaust is gounded with 1/2" braided ground strap.
2003 SVT Cobra
1984 Chevy K10
post #6 of 12 (permalink) Old 07-14-2009, 05:01 PM
Filtering the PCM with a big capacitor on the power lead to the PCM is a possibility, if that reduces the interferance but some is left a choke will help.
The capacitor goes from the 12 v switched power to ground, the choke is in the line.
keydl
keydl is offline
post #7 of 12 (permalink) Old 07-14-2009, 09:20 PM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
i know this is stuiped but where do you have the main wire running to i know i had a cb in a old chevy hook the power in the cig. lighter and i could hear the motor on it and also too it does in it your fuse box too
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #8 of 12 (permalink) Old 07-14-2009, 11:11 PM Thread Starter
power comes directly from the battery
2003 SVT Cobra
1984 Chevy K10
post #9 of 12 (permalink) Old 09-11-2010, 12:29 AM
Long Haired Country BOY!!
grizs50's Avatar
Send a message via Yahoo to grizs50 Send a message via Skype™ to grizs50
Do you have a Cell Phone charger that only comes on when you start the truck? Mine makes a lot of noise, as does my cell phone.
1995 Dodge Cummins 2500 Extended Cab UNMOLESTED!!!
http://www.youtube.com/watch?v=W8DMadLC3ZY
IF YOU HAVE TO TIE PLASTIC BALLS ON IT,IT CAN"T BE MUCH OF A TRUCK!!!
grizs50 is offline
post #10 of 12 (permalink) Old 09-11-2010, 12:30 AM
grizs50's Avatar
Or an electric fuel pump under the bed!
grizs50 is offline
XM radio robfrass 5.9L Cummins (2003-2007.5) 4 11-03-2007 04:21 AM
CB Radio SouthTexasDiese 2008-2010 6.4L Power Stroke 33 07-11-2007 12:25 AM
CB Radio Morpheus cycles The Parking Lot 19 03-07-2007 02:15 AM
DX DE AM Radio WNYPA The Parking Lot 4 04-21-2006 05:36 AM
XM Radio Motown Fire General Ford Truck and Excursion 6 01-21-2006 10:18 PM
