89 performance ?s - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cummins-dodge, this thread has received 8 replies and been viewed 1597 times.
post #1 of 9 (permalink) Old 10-10-2009, 12:08 AM Thread Starter
89 performance ?s
i am looking on getting a 89 cummins complete runnig engine with 150000 miles what kind of mods can i do to it home made and after market going to do 79 chevy conversion
01 quad cab 5spd 265000 miles cold air intake afe, cooler tubz, duel electric fans, Holley blue pump, edge jucie att. hot unlock, schied lighting pump, .093 connector tubes, ats head studs not on yet, 250 hp injector not on yet, duel 6 inch aussy stacks, 4 inch lift, eagle alloys, 35x12.50x16.5 bfg's, ranch hand front and rear bumpers
01 reg cab 5spd 266000 miles cold air intake afe, cooler tubz, single electric fan, Holley blue pump, edge jucie att. hot unlock, .093 connector tubes, duel 5 inch miter stacks, leveling kit, American racing wheels, 33x12.50x16.5 bfg's, ranch hand front and rear bumpers
cummins-dodge is offline
post #2 of 9 (permalink) Old 10-10-2009, 04:48 AM
Whats the budget and what are the goals? With the 89' you will have 9mm injector tips, so you are a little limited on the available injectors, unless you go as far as switching heads. You can also do a p-pump conversion as well. As far as pump mods to the ve, there is an AFC screw commonly called a smoke screw, and a fuel pin that can be modified as well. I'm not sure what kind of gov. mods can be made, but I'm sure that there are some.
post #3 of 9 (permalink) Old 10-12-2009, 12:03 AM Thread Starter
i would like to go with a p pump would i have to change the front cover so p pump will bolt on
what the best
ve pump
p pump
injectors
cam
turbos
post #4 of 9 (permalink) Old 10-13-2009, 04:42 PM
The front cover would need swapped to switch to a p-pump.
Now the question we need answered. What are your plans for the truck? What HP range are you wanting.
Philip is offline
post #5 of 9 (permalink) Old 10-16-2009, 12:02 AM Thread Starter
i would like 500 to 700 hp range and maybe twins where would i get the lines to go to p-pump
post #6 of 9 (permalink) Old 10-17-2009, 03:30 AM
Well that HP range puts you into P-pump range.
Don't waste your time on that 89 engine. For the cost of that engine and the p-pump swap. You can buy a running p-pump engine cheaper.
Philip is offline
post #7 of 9 (permalink) Old 10-18-2009, 03:33 AM Thread Starter
well i bought the engine for $900 complete running with 150000 miles on it
post #8 of 9 (permalink) Old 10-18-2009, 01:59 PM
Super Moderator
nevrenufhp's Avatar
Clean it up, and sell it. Then buy a P-pumped 6BT, they have been coming down in price. I've seen a few on craigslist for $1500.
Dale
or, 06 IH 7400, DT466E, 300hp
My Low Buck fuel rate site:
www.freewebs.com/nevrenufhp
nevrenufhp is offline
post #9 of 9 (permalink) Old 11-13-2009, 02:48 AM
i might know a guy that would love to buy it
silverpeteok is offline
7.3 performance 7.3stroker 1994-2003 7.3L Power Stroke 7 09-19-2007 03:47 AM
Performance For A CAT C7 CAse_26 General Diesel 1 09-16-2007 11:00 PM
Best performance for TDI? imported_Dieselfever Euro-Diesels 5 06-14-2007 09:23 PM
7.3 performance ??'s 1bad01 1994-2003 7.3L Power Stroke 12 01-16-2006 05:17 PM
