91.5 heater motor?! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by wistlnwoodchuck, this thread has received 2 replies and been viewed 1135 times.
post #1 of 3 (permalink) Old 10-10-2009, 01:33 PM Thread Starter
91.5 heater motor?!
I recently bought a 91.5 cummins and the heater blower doesnt work I replaced the switch and thats not it.. maybe the motor itself. the fuse is fine so thats not it either also is there a link to a "how to" change this? thanx
2004.5 GMCcc, sb, 4" straight pipe from turbo back, lly dmax, afe stage 1, 315 75 16 big o a/t, egr blocked ,billstiens all around,2 dvd's, nav, slt package,
wistlnwoodchuck is offline
post #2 of 3 (permalink) Old 10-11-2009, 03:37 AM
Up behind the glove box is a resister setup mounted into the cowl area. This is used to controll fan speeds. Check and see if you have power coming and going out of it.
Philip is offline
The Following User Says Thank You to Philip For this addition to TDG:
wistlnwoodchuck (10-12-2009)
post #3 of 3 (permalink) Old 11-26-2009, 04:00 PM
RAM-Man
Denman's Avatar
My blower motor glitch was the two-conductor connector nearest the motor, under the hood, passengers side firewall. My blower has a soft plastic cover which concealed the connector, but when I hot-wired it it fired right up.
Denman is offline
oil pan heater ? dwoz2012 2008-2010 6.4L Power Stroke 11 01-28-2009 10:16 PM
Heater 2fast2reid 2003-2007 6.0L Power Stroke 6 12-24-2008 08:13 PM
Supplimental Cab Heater... Mbixler 2008-2010 6.4L Power Stroke 6 12-21-2007 05:56 AM
Water Heater? D_B The Parking Lot 6 12-15-2006 10:18 PM
No Heater? worktruck General Ford Truck and Excursion 1 11-02-2006 02:14 AM
