92 mods - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 9512valve, this thread has received 4 replies and been viewed 862 times.
post #1 of 5 (permalink) Old 11-17-2009, 06:26 AM Thread Starter
Diesel Outlaw
9512valve's Avatar
92 mods
ok my buddy has 100hp injectors, m5 fuel pin, gov spring, and a little tuning i havnt drove it yet but he said compared to his buddys truck it doesnt feel like it has that much power. what can i do as far as tuning to get this thing dialed in?
dont remember
9512valve is offline
post #2 of 5 (permalink) Old 11-17-2009, 03:34 PM
Do a fuel pressure test.
What you have listed could be more than a stock high milage lift pump can handle.
Philip is offline
post #3 of 5 (permalink) Old 11-17-2009, 03:59 PM Thread Starter
Diesel Outlaw
9512valve's Avatar
how do you do a fuel pressure test on these pumps?
dont remember
post #4 of 5 (permalink) Old 11-18-2009, 03:37 AM
You need to get a taped banjo bolt. Pull the banjo bolt on the oulet side of the fuel filter. Install the taped banjo bolt and then install a gage.
On a stock lift pump you should see 5 to 7 PSI at idle. If your showing any less than 5 PSI. Throw a new fuel filter on it and see what it does.
Do a test drive and see what the PSI is at WOT.
Postback and let us know what it reads.
Philip is offline
post #5 of 5 (permalink) Old 11-18-2009, 06:11 AM Thread Starter
Diesel Outlaw
9512valve's Avatar
ok ill see when he can get it done i work a lot and dont even have enough time for my truck so ill let him know what to do and get back to you thanks for everything
dont remember
help with mods stickhorse 6.7L Cummins (2007.5-2011) 2 01-18-2008 02:55 AM
Engine mods Vs tranny mods Squamish smoker 2003-2007 6.0 Tuner Forum 1 07-12-2007 02:44 PM
What happens with big mods Robts 2003-2007 6.0L Power Stroke 13 07-03-2007 09:50 PM
What mods? diesel_ram_man 5.9L Cummins (2003-2007.5) 13 06-09-2006 12:45 AM
