first gen dodge problems and goods - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by balz out, this thread has received 14 replies and been viewed 9507 times.
post #1 of 15 (permalink) Old 11-20-2009, 09:40 PM Thread Starter
balz out's Avatar
as my sig shows im a powerstroke man but i deal for a gen 1 came my way. reg cab new trans (auto) truck has under 100,000 original has a cap and plow on it body is not bad at all needs powersteering pump and something else. i have been lookin around over here at mods and what these trucks can do and for under a grand you can get them moving. i wanted to know if there are any bad problems with these trucks before i buy. the gentleman said he will take 2500. gonna offer 1750 no plow or cap
2000 f350 7.3 ext cab 6speed- 4inch dp, 5inch straight pipe, ts 6 pos chip. stock 140 100 75 50 high idle, zoodad, fpr shimmed, 6637 intake, 5inch lift, foil delete, beans idm, stage one injectors....r.i.p was fun when it lasted
94 mack rd e7350 mack 12speed roll bed
balz out is offline
post #2 of 15 (permalink) Old 11-21-2009, 01:57 AM
Need a little more info. nonIC or IC'd??
$2500 is a decent price if the body isn't rotted off. Your area is like mine. Just about center of the rust belt.
Philip is offline
post #3 of 15 (permalink) Old 11-21-2009, 02:44 AM Thread Starter
balz out's Avatar
can u give me a little info on both i/c and non i/c. no matter what i want it as long as there is nothing major wrong... im going to be getting a 6.0 i/c for my 7.3 so i was going to take the i/c off of the 7.3 and put it on dodge if it is non i/c
balz out is offline
post #4 of 15 (permalink) Old 11-21-2009, 08:28 PM
89 to 91.5 year model trucks were nonintercooled with getrags or 727 automatic's. The 727 trucks came with 3:07 gear ratio's in them. Because the 727's are not a OD trans.
91.5 to 93 year model trucks were intercooled with getrags and 518 automatic's. The 518 is a OD trans.
Philip is offline
post #5 of 15 (permalink) Old 11-21-2009, 08:59 PM Thread Starter
balz out's Avatar
are those trans both as bad as each other or is one nicer than the other one is
balz out is offline
post #6 of 15 (permalink) Old 11-22-2009, 04:04 AM
The getrags last pretty decent. The main issue with them is the design. They use tapered roller bearing. when they wear the trans starts to make noise. When you hear it that means time to repair. If not you will be replacing it.
the auto's aren't to bad. The main issue is Dodge threw a very loose converter in. If the engine is stock the converter feels all right. Once you turn the power up just a little. The converter slips bad.
Philip is offline
post #7 of 15 (permalink) Old 11-23-2009, 04:27 AM
When the converter slips it gets hot, put a trans temp gauge on, look at the charts on fluid life and decide how often you want to change the fluid.
keydl
81 Isuzu /C223na, 5spd
keydl is offline
post #8 of 15 (permalink) Old 11-23-2009, 07:39 PM Thread Starter
balz out's Avatar
how to tell which trans it is? does it have a certain stamp code or will it have stamped on it getrags or 727 etc...
balz out is offline
post #9 of 15 (permalink) Old 11-23-2009, 07:56 PM
BigRed Cummins's Avatar
The Getrag is a 5spd manual, 727 is a 3spd auto and the only auto in non-intercooled trucks from 1989-1991.5. The A518 is an automatic that came in auto equipped and intercooled trucks from 1991.5 to 1993
1992 W250-P-pump and some extra air, gone, but not forgotten.
2003 SVT Cobra
1984 Chevy K10
BigRed Cummins is offline
post #10 of 15 (permalink) Old 11-25-2009, 04:03 PM Thread Starter
balz out's Avatar
this truck is a auto i know that much i beleive it is a a518 i beleive the truck is a 93 will find out today. the mods i plan on doing is turning pump up fuel pin stronger valve springs water/meth kit. some type of custom trans cooling kit injectors bhaf and some little things here and there. will stock auto trans hold up? and gauges are being installed first and formost
balz out is offline
good selection of 7.3 goods for sale! 03f3507.3 Whats Been Sold 12 01-07-2008 10:33 AM
03 Dodge Problems???? thejdman04 5.9L Cummins (2003-2007.5) 22 07-29-2007 01:27 AM
Maybe we should stop buying Chinese goods now eh? BROKER The Parking Lot 5 02-18-2006 09:51 PM
V-10 dodge emmisions problems?? Deezle1 General Dodge Discussion 4 09-16-2005 12:30 AM
