Borgeson Steering Shaft - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BlowinSmoke, this thread has received 4 replies and been viewed 1017 times.
post #1 of 5 (permalink) Old 11-23-2009, 09:22 AM Thread Starter
BlowinSmoke's Avatar
Would anyone happen to know if these newer steering shafts by Borgeson would work for a truck with a 6" lift even though the site says it will accomodate up to a 4" body lift. Mines got the slip joint at the gear box and the flanged connection under the hood. Thanks for the input.
BlowinSmoke is offline
post #2 of 5 (permalink) Old 11-23-2009, 01:51 PM
Diesel Duo's Avatar
I put one on my '94. I do not know how expandable(length) are though. I believe it is the same length as stock just a bettet unit. The factory one colapeses in front impact.
Hope it helps
DD
No brand loyalty, just a love of diesels!!
1994 Ram 2500 CTD K&N intake, MBRP exhaust, full Goerend tranny, #100 Fuel plate, 60# valve springs, 4k GSK, Thuren steering stabilizer, Thuren Track Bar, +2.5" progressive rate coil springs, Bilstein 5100's, BD Diesel SBS, chassis mods, 315/75R16 Goodyear Wrangler Duratrac, Isspro tri-pod EGT, fuel, and boost, Eclipse CD, 8' Boss snowplow
Fuel Heater Deleted! KORE dual Heim Joint end links waiting to go in
2004 F-250 Powerstroke aFe stage II, Hypertech PTM, Recon mirror markers, Firestone airbags w/ compressor, Rancho 9000's on all four w/ myride, 20" Pacer on 33/12.5 Nitto Mud Grapplers, Eclipse CD, 8' Boss snowplow
Blizzard IceChaser 1.5 cubic yd. poly salt and sand spreader!
Diesel Duo is offline
post #3 of 5 (permalink) Old 11-23-2009, 03:17 PM Thread Starter
I think I'm going to give them a call and see if they know now that its monday here. Is your 94 lifted at all? My thing is why try to buy it and see if it works if I can get some input first. The slip joint does fine, but after how long will it break again.
post #4 of 5 (permalink) Old 11-23-2009, 04:19 PM
BigRed Cummins's Avatar
A suspension lift has no effect on the steering shaft. Only a body lift would, because it requires a longer shaft. The drag link and steering assembly after the box is what is affected by a suspension lift.
1992 W250-P-pump and some extra air, gone, but not forgotten.
2003 SVT Cobra
1984 Chevy K10
BigRed Cummins is offline
post #5 of 5 (permalink) Old 11-23-2009, 04:24 PM Thread Starter
Ah, sweet so there shouldnt be any problem there then. Guess it helps to know the difference in lifts Thanks
intermediate steering shaft HIGH MILEAGE ELITE 5.9L Cummins (Pre 1994) 1 11-03-2009 08:10 PM
Steering shaft Cummins-Powerstroke 5.9L Cummins 12 Valve (1994-1998.5) 0 05-09-2009 08:20 PM
Play in Steering, new shaft? blueovalcj General Dodge Discussion 1 08-10-2007 04:36 AM
New steering shaft Mike L. Duramax 2004.5-2005(LLY) 60 05-31-2007 11:15 PM
New Steering Shaft mckey73 General GM Truck Forum 8 04-11-2007 01:29 AM
