Rotor Hub - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BlowinSmoke, this thread has received 10 replies and been viewed 1545 times.
post #1 of 11 (permalink) Old 11-27-2009, 04:13 PM Thread Starter
BlowinSmoke's Avatar
Rotor Hub
I cant seem to find anything on this. The Hub Housing attached to the rotor, does anyone know a way to get the studs out and that housing off/on the rotor itself?
BlowinSmoke is offline
post #2 of 11 (permalink) Old 11-27-2009, 05:11 PM Thread Starter
Ok, so I learned fast its the housing is just held to the rotor by the pressed in studs. Would anyone happen to know of a place to purchase a new housing assembly? I cant seem to narrow a search and most places dont have it.
post #3 of 11 (permalink) Old 11-28-2009, 02:24 AM
The bearing spun in the hub as well as on the spindle?
If the hub flange indicates less than .0005 ( that is 1/2 a division on a .001 dial ) and will dry assemble to the same mark you can use stud lock to glue it in place.
If it is worse off a machine shop can slick it to mount a sheet metal shim so the bearing is concentric with the flange and rotor.
Knock the studs out with a nut to pad the end, best is 2 nuts jambed with the stud 1/16th or so down from flush. Common practice is to use a lug nut and then use an impact wrench to reuse the lug nut even if the end is damaged. I mostly use already damaged lug nuts from my tool box.
Going back in with out a press, balance the hub rotor on a deep socket so the stud will clear and not burr the threads, I use a 12 in drift punch and a 2 or 6 # hammer, moderate until the tone changes and then about twice as hard to set it, then across the pattern to the next one.
Knock the trash/rust/dirt off the matching surfaces so they will clamp correctly. If the stuff crushes it can lead to loose wheels.
Check part #s to see if a rear hub will fit - some do.
keydl
81 Isuzu /C223na, 5spd
keydl is offline
post #4 of 11 (permalink) Old 11-28-2009, 09:48 AM Thread Starter
Yes. Since I'll be with the truck tomorrow I'll take pictures of it, its actually quite impressive and I cant say I've ever heard or seen anything like it myself.
The inner bearing was the only one intact. The outer bearings inner race welded itself to the spindle and the cone race welded itself to the inside of the hub. I took a torch to the hub and beat on it, nothing. Dad picked up dry ice to shrink it out, nothing. The area where you could tap that out inside the hub looks like a well used brass or aluminum mallot.
Thanks on the rear hub never thought off that although I did see a tech page where people have taken the DRW hubs and machined the outer tire mounts off the housing.
post #5 of 11 (permalink) Old 11-29-2009, 06:29 AM
If you are good with a torch you can gouge the race so it will break out with a shaped chisel. Make 2 cuts about an inch apart and grind the chisel to the joint hub to race. Use a press or a 6# hammer. If the piece comes loose it will sing as it flies if the is no cover.
Ice on the hot section between the cuts will help.
Grinding slots with a Dremel type tool is another way, slots into the ledge that stops the race are no problem - even every inch or 2 all the way around.
If all else fails the segment will pop out if heated red with a tin shield to keep the hub cool.
Next time will you stop when the damage starts? That way you just peel the cage and drive the rollers around so they will come out. Not easy but a lot cheaper. I have also blown a segment of the cone with a torch and driven the bits in to drop the rollers out, and recovered the balance of the parts. Just bearings and seals.
keydl
keydl is offline
post #6 of 11 (permalink) Old 11-29-2009, 10:30 AM Thread Starter
If I knew that, that damage was starting in a safer spot then when it did yeah I probably would have stopped. The first time I knew anything was going on was at 70 on the highway and then again a few seconds later. This was a violent jerk to the left as the drivers side took damage. I got the truck off the road into the next town, called home and waited 7 hours for a trailer. Then had to get it on the trailer. Interesting night I'll never forget.
post #7 of 11 (permalink) Old 11-29-2009, 11:40 PM Thread Starter
Sad incident this is and costly
-Bearing cone inside hub-
-Backside of bearing cone-
-Bandsaw cut the race and beat one half off-
-You can really see how it welded itself-
post #8 of 11 (permalink) Old 12-02-2009, 04:47 AM
That is annoying when the machines don't cooperate.
With the cut off disc worn down to fit in, cut a pair of slots so a 1in section of the race so it will break out. Grind a chisel to the radius to drive behind the shell. When the shell breaks the piece leaving will have a lot of energy - guard it so it goes where you want it to so it does not hit stuff like eyes and teeth. The big piece may need a cut but will probably break out in 3-4 pieces - same caution. The worn cutoff wheel can be used to knock off the high spots so a new race can be put in. You will need googles and a face shield to see the pattern that it is even all the way around. One of the places that the guard won't fit. When you are finished the race needs to drive the same as the others, if not use stud and bearing lock glue.
With the internal splines there is no interchange with rear hubs.
If you can find one - replacement is better, used may have bearings with it.
keydl
keydl is offline
post #9 of 11 (permalink) Old 12-02-2009, 01:40 PM Thread Starter
Yes little bit of a pain
I ordered new hubs which come in a pair from Spyntec Industries LLC. should be here before this weekend so I can finally get the front end finished.
Got a new spindle from Mad4wd along with all the seals. But a bonus is that a new spindle comes with all the internals in place and pregreased and the supply you with the two external seals for it. The new spindle seal kit comes with all internal/external seals.
I'm just going to mic the new spindle and try to get the old spindle to a machine shop as with the hub.
Thanks for the help and advice in this thread. Hopefully it doesnt happen again.
post #10 of 11 (permalink) Old 12-03-2009, 07:46 AM
Generally good for 3-400k except for racing
keydl
keydl is offline
Powerslot rotor calebgriffin31 Supporting Vendors Forum 1 11-17-2009 01:15 AM
Help Trying to Separate Rotor from Hub OBS 75stroppe 1994-2003 7.3L Power Stroke 18 10-08-2007 06:07 PM
rotor replacement Diesel Fanatic 5.9L Cummins (1998.5-2002) 5 06-28-2007 04:52 AM
rotor replacement??? jimmydager General Ford Truck and Excursion 3 04-13-2007 11:30 PM
Rotor removal Help! RockStar General Ford Truck and Excursion 1 04-20-2006 11:33 AM
