Daully conversion - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by StrokerAce, this thread has received 7 replies and been viewed 930 times.
post #1 of 8 (permalink) Old 01-26-2006, 06:55 PM Thread Starter
Daully conversion
Looks like alldiesels is getting that 90' cummins. What would it take to make that 2wd a daully? Whats a good cheap conversion kit? And do the little fenders bolt on to a factory bed, and where can he get some of those cheap?
StrokerAce is offline
post #2 of 8 (permalink) Old 01-26-2006, 07:31 PM
Needs an axle, and any body shop can get the fenders.
Timbeaux38 is offline
post #3 of 8 (permalink) Old 01-26-2006, 07:40 PM Thread Starter
I thought they had a bolt on kit?
post #4 of 8 (permalink) Old 01-26-2006, 07:43 PM
For the fenders? I dont think they are a bolt-on item but I could be wrong
post #5 of 8 (permalink) Old 01-26-2006, 07:47 PM Thread Starter
no i meant for the actual duals, i thought there was a bolt on kit, i didnt think you needed a whole new axle, and dont you have to space your fronts as well?
post #6 of 8 (permalink) Old 01-26-2006, 08:11 PM
You would have to space your fronts, and wether or not you can dual the back depends on the axle in the truck. You can bolt the spacers on and add duals, but it may look a little wonky...
post #7 of 8 (permalink) Old 01-26-2006, 09:45 PM
haz-mat19's Avatar
I would think that you would have to cut the fenders out also to clear the outside tire, I could be wrong though.
'01 xcab 4x4,Suncoast by Mike L. Goerend triple, edge III, AFE stage II, HTT 62/12, FASS, and other stuff
haz-mat19 is offline
post #8 of 8 (permalink) Old 01-26-2006, 09:54 PM
You might have to put longer studs on the rear axle to be able to run both rims, but all the 1st gens had Dana 70's, 2500 and 3500 automatic or manual. The fenders would have to mounted on the box along with the box seals, no fender trimming required. I have also seen dually's run 2500 rims on the front axle, I guess it would be up to the installer.:smoke: :smoke:
imported_Smokem is offline
