Hub Swap Problems - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BlowinSmoke, this thread has received 2 replies and been viewed 1034 times.
post #1 of 3 (permalink) Old 12-17-2009, 11:49 PM Thread Starter
BlowinSmoke's Avatar
Hub Swap Problems
I just used a forged steel hub housing in replacement of the cast hub housing. Your supposed to use a different rotor, Chevy. Because the dodge rotor wont fit. All the bearings and seals are all the same. But the rotor doesnt fit to where the caliper and brake pads are. I got all this information from Solid Axle.com or spyntec industries Maybe they missed telling me something. Help would be great cause now Im stuck with all these new parts and somethings naked eye wrong.
BlowinSmoke is offline
post #2 of 3 (permalink) Old 12-18-2009, 05:39 AM
BigRed Cummins's Avatar
if you swapped to chevy rotors and hubs, you will most likely have to use chebby calipers and caliper brackets. BTW there are two different style rotors for our trucks, (2 different offsets) Just my .02.
1992 W250-P-pump and some extra air, gone, but not forgotten.
2003 SVT Cobra
1984 Chevy K10
BigRed Cummins is offline
post #3 of 3 (permalink) Old 12-18-2009, 08:28 AM Thread Starter
Your .02 is worth it. Thats what I'm wondering about how to get that done, already put so much into it wondering if searching a junk yard for the original cast iron hub housing and selling off the new housings and rotors since they've never been used just put together to the point where I wasnt informed to well and need more parts.
ZF 6 Swap Zaairman 1994-2003 7.3L Power Stroke 42 11-27-2009 05:03 AM
gas to 6.5L swap turbopsd01 6.5L Diesel Engine 2 08-31-2007 05:39 AM
Electrical problems/dash problems curtis2003 5.9L Cummins (2003-2007.5) 1 10-21-2006 08:27 AM
HX-35 Swap 6Lcummins 5.9L Cummins (Pre 1994) 1 09-24-2006 02:21 AM
5.0 to a 6.9 or a 7.3 swap countryboy88 1994-2003 7.3L Power Stroke 13 03-10-2006 01:34 PM
