Aftermarket ve pumps - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bad_cummins, this thread has received 3 replies and been viewed 5591 times.
post #1 of 4 (permalink) Old 01-25-2010, 07:14 PM Thread Starter
A friend of mine wants me to replace his fuel pump do to a leak. Apparently its pretty serious. He wants to know if there are any avaliable aftermarket pumps that will make a little more power. He is shooting for 250 to 300 horse. Any ideas where to look and who makes a pump?
01 Qc Cummins 4x4 long box, edge attitude with juice (HOT!!), 4" exhaust, afe stage 2 intake, HTB2 62/12, banks intake pleum, bully dog big fuel kit, stage three jammers, southbend 3250 DD, BD Blow off valve. PDR master and slave cylinder upgrade. Sold
2006 mega cab 4x4 auto. Stock for now.
bad_cummins is offline
post #2 of 4 (permalink) Old 01-25-2010, 08:05 PM
Official TDG Doctor
hccumminssmoke's Avatar
Brian Block does/did make 14mm VE Pumps...he's out of Shelbyville, KY, and was mentioned in the article in Diesel Power, not to long ago...
Number: Brian Block (502) 633-1515
Diesel Power Article
http://www.dieselpowermag.com/tech/d...sel/index.html
Originally Posted by From the DP Linky Above
Injection Pump
There are some simple tweaks you can perform to the VE injection pump to get an extra 100 hp. In the last few years, people have started making custom parts for these pumps to increase their fuel output even more. Brian Block, one of the original VE gurus, designed a 14mm injection pump head that can flow a lot more fuel than the stock version. The upside to the 14mm is a 100-horsepower increase over stock; to date, the only VE trucks over 600 horsepower at the wheels have used Brian's pump heads. Rocken-Tech is another company that builds parts for the VE, and their 4mm cam plate and 14mm head have also been used successfully at power levels over 400 hp. With either of these 14mm heads, an ultra-high-flow lift pump is necessary to maintain injection pump longevity.
Nate
hccumminssmoke is offline
post #3 of 4 (permalink) Old 01-25-2010, 10:22 PM
JDolezal's Avatar
I was just on PDR's web page earlier looking at stuff for my 1st gen and they will build a pump to what you want. At least thats what it said. Then they have a "hot rod" VE pump for 500+ hp. I'll get the link and post it.
http://www.pdrdiesel.com/products/VE...d-559-124.html
JDolezal is offline
post #4 of 4 (permalink) Old 01-27-2010, 01:02 AM
BigRed Cummins's Avatar
most common on a VE is the front seal. Usually due to too much lift pump pressure. It is an easy fix if you can pull the pump. Also, the fuel pin o-ring, can and will leak if you have too aggressive of a fuel pin.
1992 W250-P-pump and some extra air, gone, but not forgotten.
2003 SVT Cobra
1984 Chevy K10
BigRed Cummins is offline
Those of you with aftermarket fuel pumps... 6L strokin 2003-2007 6.0L Power Stroke 12 01-17-2009 12:05 PM
aftermarket fuel pumps? imported_6.0superduty 2003-2007 6.0L Power Stroke 27 02-18-2008 02:09 PM
hard starting IPs, fuel pumps and lift pumps jvbutter 7.3L and 6.9 IDI (Pre 1994) 5 11-08-2007 05:57 AM
New LB7 and LLY CP3 pumps TonyBurkhard Whats Been Sold 0 10-27-2007 06:40 PM
