Steering issue - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by countrysmoker, this thread has received 2 replies and been viewed 1113 times.
post #1 of 3 (permalink) Old 02-17-2010, 05:13 AM Thread Starter
Steering issue
New to the garage , so hey to all of you! I have a 93 and am having problems out of the power steering. I lost all pwr. steering yesterday,put new pump on today and still no pwr. Is this a gear issue or what? Anyone else out there had this problem? Love my truck so much I bought another virgin just like her with only 158k actual. One is good and two is better!
countrysmoker is offline
post #2 of 3 (permalink) Old 02-18-2010, 04:14 AM
Pump or gear box - without the tool to check the pump pressure it is a 50-50 chance, well not quite, it IS the pump about 7 of 10.
With the truck moving slow dial the steering wheel lock to lock 3-4 times and check the fluid level. If bleeding the air out does not help and the pressure hose is not leaking then it is the gear box.
81 Isuzu /C223na, 5spd
keydl is offline
countrysmoker (02-18-2010)
post #3 of 3 (permalink) Old 02-18-2010, 05:29 AM Thread Starter
steering issue
I actually figured out the problem today after going through all the steps and it was vacume locked at the booster. Feel real stupid for not checking that first! Thanks for the suggestion , I tried that and when taking it off to check the gear is when I found the problem. Now I know what to look for next time . Again, thanks for your help , truely a [email protected]##$ to drive without power steering.
power steering issue (Question de direction assistée ) french277 General GM Truck Forum 0 05-11-2009 05:37 AM
Power Steering issue ???? gratcliffe 1994-2003 7.3L Power Stroke 3 04-28-2009 06:12 PM
Synthetic atf power steering flush issue! mmmdiesel 1994-2003 7.3L Power Stroke 6 02-15-2009 07:08 PM
power steering pump bracket issue dieselman723 1994-2003 7.3L Power Stroke 4 01-28-2008 01:10 AM
steering issue SmokeyMtnKid 1994-2003 7.3L Power Stroke 7 07-29-2007 03:40 AM
