2cd gen injectors in 1st gen...? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by gon2sea, this thread has received 4 replies and been viewed 1072 times.
post #1 of 5 (permalink) Old 03-22-2010, 11:39 PM Thread Starter
would a set of 215hp stock 2cd gen injectors fit in a 1992 1st gen...
gon2sea is offline
post #2 of 5 (permalink) Old 03-23-2010, 04:35 AM
BigRed Cummins's Avatar
They will physically fit yes, but they have too high of a pop-off pressure. The p-pump is much higher pressure than the VE.
1992 W250-P-pump and some extra air, gone, but not forgotten.
2003 SVT Cobra
1984 Chevy K10
BigRed Cummins is offline
post #3 of 5 (permalink) Old 03-31-2010, 02:36 AM
The injector lines will not thread on eather. P-pump engines had different threads on the injector bodies.
Philip is offline
post #4 of 5 (permalink) Old 03-31-2010, 06:47 PM
PhilipR's Avatar
Also Non I/C engines used a 9mm tip and I/C'd engines used a 7mm tip. The P-Pump trucks use the 7mm tip as well.
-Phil-
PhilipR is offline
post #5 of 5 (permalink) Old 04-01-2010, 12:00 AM
SSpeeDEMONSS's Avatar
also 155 vs 145* spray pattern.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
Looking for a set of 250 cc or bigger injectors in trade for my II 185 cc injectors mikes06lariat Ford Parts wanted 1 08-12-2009 02:52 AM
Performance Injectors Or Stock Injectors imported_Stroker01 1994-2003 7.3L Power Stroke 8 05-06-2008 04:16 PM
Injectors 02sprtcumns 5.9L Cummins (1998.5-2002) 10 11-06-2007 07:25 PM
I Need new injectors 96ford Supporting Vendors Forum 3 11-05-2007 02:49 PM
Injectors.... pedro_8149 7.3L and 6.9 IDI (Pre 1994) 3 10-02-2007 02:42 AM
