INJECTORS - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by MILKINGCOWBOY, this thread has received 12 replies and been viewed 3081 times.
post #1 of 13 (permalink) Old 04-23-2010, 05:59 PM Thread Starter
milkin cowboy
MILKINGCOWBOY's Avatar
Send a message via AIM to MILKINGCOWBOY
INJECTORS
Hi my girl friends 93 started having injectors leak and they have 250,000 on em so its time for some new ones. I would like to up grade to a mild and reasonable priced injector. I am not sure what would be a good match. It's an auto with no mods besides bhaf and open exhaust. down the road she wants the pump turned up a little and maybe someday some turbo work. She plans on do some occasional towing 10,000 lbs or so, a little 3 horse steel goose neck. i am going to put a pyro in for her but still......u know......I was looking at the prince of darkness (POD) injectors any input on them or other recommendations? She would like not to lose much on the mpg's thanks
2002 3500 6 speed ex. cab 4x4 custom flatbed farm truck 9,120 lbs. light weight ALL WAYS HAULIN HAY, CATTLE OR A-$-$!!!! BHAF,4" OPEN STACKS,EDGE JUICE WITH ATTITUDE, AIR DOG II 100,SOUTH BEND CLUTCH
1982 IH Transtar Eagle 4370 turned up 400 Cummins big cam, straight 6" bull haulers one hell of a
Jake and 13 speed od
White 2-105 tractor with 354 Perkins
White 2-135 tractor with 478 White/Hercules
KEEP ON KEEPIN ON
SUPPORT AMERICAS DAIRY FARMS
http://i17.tinypic.com/4u2drv8.jpg
http://profile.myspace.com/index.cfm...ndid=137814954
MILKINGCOWBOY is offline
post #2 of 13 (permalink) Old 04-23-2010, 07:14 PM
BigRed Cummins's Avatar
I would go with stock, or 190's with a stock transmission. IIRC 190's are actually smaller than stock, but you get a performance and a mileage boost due to better atomization. I have a set of stockers out of a 1992 intercooled if you are interested. They work fine in my truck before I did the P-pump.
1992 W250-P-pump and some extra air, gone, but not forgotten.
2003 SVT Cobra
1984 Chevy K10
BigRed Cummins is offline
The Following User Says Thank You to BigRed Cummins For this addition to TDG:
MILKINGCOWBOY (04-24-2010)
post #3 of 13 (permalink) Old 04-24-2010, 03:20 PM
I am no longer sure what year will interchange but you can run P-pump injectors in a VE pump engine. The only issue I can think of is some years have a larger size injector tip and in that case you would need a bushing. Also have the pop pressure set for the type of pump you are running.
later is offline
post #4 of 13 (permalink) Old 04-26-2010, 02:58 PM
89-91 non intercooled have a 9mm injector tip. 91.5-98.5 have the 7mm injector tip. The 7mm heads are more desirable because apparently the 9mm heads are prone to cracking.
2003 SVT Cobra
1984 Chevy K10
post #5 of 13 (permalink) Old 04-26-2010, 08:22 PM
PhilipR's Avatar
P-pump and VE pump have different pop pressure...the injectors will bolt in like BRC stated but they won't run right.
-Phil-
PhilipR is offline
post #6 of 13 (permalink) Old 04-26-2010, 09:11 PM
He covered that, albeit vaguely. And the threads where the injector lines thread on are different as well I believe.
2003 SVT Cobra
1984 Chevy K10
post #7 of 13 (permalink) Old 04-26-2010, 11:32 PM Thread Starter
milkin cowboy
ok so then what would be good options ? part numbers?
KEEP ON KEEPIN ON
post #8 of 13 (permalink) Old 04-26-2010, 11:56 PM
On some the nuts are a different size, You will need to check to see what size injector you have, or you can send what you have out and get them reworked, or change to the correct injector lines for second gen injector. POD's should be about the same as a 370 injector.
later is offline
post #9 of 13 (permalink) Old 04-27-2010, 05:45 AM
But with a stock auto pulling a three horse steel gooseneck, PODs are gonna toast that transmission, not to mention the pistons if the trans holds together long enough. PODs, like 370s, have the wrong spray angle, so they are smokey and hot. I would go very mild unless you plan to do major trans upgrades in the near future. I would at least do a converter and valvebody if you plan on putting some good power down. Like I said, stockers, or 190s with a little pump tweaking will probably get her where she wants to be. Also, post over in the vendors forum and see what they have to say. They may be able to hook you up with what you want.
2003 SVT Cobra
1984 Chevy K10
post #10 of 13 (permalink) Old 04-27-2010, 02:02 PM Thread Starter
milkin cowboy
thanks , I did post over there but no replys, do you have the bosh number for the 190s?
KEEP ON KEEPIN ON
Looking for a set of 250 cc or bigger injectors in trade for my II 185 cc injectors mikes06lariat Ford Parts wanted 1 08-12-2009 02:52 AM
dt 466 injectors tdc-racing Medium and Heavy Duty 9 01-17-2009 04:15 PM
Performance Injectors Or Stock Injectors imported_Stroker01 1994-2003 7.3L Power Stroke 8 05-06-2008 04:16 PM
Injectors gotpsd? 1994-2003 7.3L Power Stroke 52 05-22-2007 03:46 AM
DIY Injectors anyone done it JWC-PERFORMANCE 1994-2003 7.3L Power Stroke 38 05-08-2007 11:07 PM
